03-05-2008, 12:53 | #1 (permalink) | |||
No Life Poster Join Date: Dec 2006 Location: Your_Home Age: 38
Member: 413053 Status: Offline Sonork: 100.114351 Thanks Meter: 458 | N73 10/10 3/3 counter 100% ok with bb5box.... thanks go bb5team.......................hare is log... Quote:
The Following User Says Thank You to .::LUQMAN::. For This Useful Post: |
03-05-2008, 23:49 | #4 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Thanx For You Man For This Info.. |
03-11-2008, 16:50 | #10 (permalink) |
Freak Poster Join Date: Mar 2005 Location: tehran Age: 38
Member: 126615 Status: Offline Thanks Meter: 3 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v48_26-06-07_RM-133_(c)_Nokia. IMEI: 358634018296131 SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Block 2: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_358634018296131_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v48_26-06-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 1000 miliseconds Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Block 2: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. heeeelp me |
flashig z540 100% ok with boot | electronica gsm | QUALCOMM Models (3G) | 6 | 03-04-2012 15:42 |
Full MobiMB 2008 for 2600c,1200,1110,1650,7610,6630,n73 etc-All s40,s60,s60v3 100% ok | mehedi.h.j | Nokia Multimedia | 61 | 09-24-2009 16:22 |
n95 flashed 100% ok with HWK, so all users need check their cables.... | .:GSM International:. | HWK | 24 | 05-29-2008 06:35 |
