Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2003 Location: Palestine Age: 29
Member: 26041 Status: Offline Thanks: 0
| N73 Successfully Unlocked without MicroScope ! Hi Friends Today i unlocked N73 without Microscope Just open your eyes and connect correct TP ![]() Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2449100072467690 Block 1: OPEN Type 5 Data: 24491F Block 2: OPEN Type 5 Data: 24491F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfullh, Turkish Regards. |
| | #5 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Rawalpindi Pakistan Age: 8
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks: 284
| Quote:
its more easy to unlock n73 without microscope i also had done alot without microscope | |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks: 93
| the only way you can do it without TP for the one under the flash is to count 8 balls that are under the RAP and move the needle underneath flash. It would be better still to use a small thin needle so as to avoid making pressure and bending the probe on the flash.use scotch tape to insulate the copper section near the dual IC and avoid nasty results. |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2002 Location: I
Member: 15238 Status: Offline Thanks: 40
| Count 8 balls from left. Count 3 from right. Use a permanent marker pen to mark the particular balls. AND then any source of light will en light the marked region. U can view 'em with ***** eyes now. IT is now damn easy. FOR precise results use syringes !! |
| | #13 (permalink) | |
| Quote:
you are right . i use small needle insteed of CLK pin then i put the CLK in 10 as in the picture which equal 8 in above and put DATA in the 3 from right as in the picture. Thats All Best Regards. | |
| | #14 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: -worldwide-
Member: 592460 Status: Offline Thanks: 264
| Quote:
| | #15 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: algeria Age: 43
Member: 189532 Status: Offline Thanks: 69
| heyheyehey Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| BB5 unlocker & N73 successfully unlocked | Dooha_Bd | Nokia Base Band 5 ( BB-5 ) | 3 | 02-21-2010 17:19 |
| Post Here Successfully Unlocked without TP BB5 Phones | Ja\/\/aD | Universalbox | 70 | 01-10-2009 13:52 |
| ....::::W850 Cid 52 SuCceSsFul Unlock WithOut Problem::::... | nasirkhan007 | SETool2 | 1 | 05-28-2008 18:49 |
| N73 Successfully Unlocked!!! | nlogomaster | Nokia Base Band 5 ( BB-5 ) | 15 | 07-24-2007 11:06 |
