Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004 Location: La Union Philippines
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks: 1,797
| >>> N75 Unlocked Successful <<< ![]() ![]() ![]() ![]() Quote:
br RNC_EBM | |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks: 1,762
| Good job .... another Unlocked!!! Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354***************x SP LOCK status: Config Key: 7340400023927779 Block 1: CLOSED Type 5 Data: 732123 Block 2: CLOSED Type 5 Data: 21407F Block 3: CLOSED Type 5 Data: 21402F Block 4: CLOSED Type 5 Data: 74000F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70403F Block 7: CLOSED Type 5 Data: 70604F Block 8: CLOSED Type 5 Data: 71402F Block 9: CLOSED Type 5 Data: 71030F Block 10: CLOSED Type 5 Data: 71606F Block 11: CLOSED Type 5 Data: 73002F Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 74807F Block 14: CLOSED Type 5 Data: 73404F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Skip autobackup of PM 308 Autobackup file: RM-128_3***************x_Locked_Keycnt_0_Fbuscnt_0__V _06wk15v37_08-03-07_RM-128_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7340400023927779 Block 1: OPEN Type 5 Data: 732123 Block 2: OPEN Type 5 Data: 21407F Block 3: OPEN Type 5 Data: 21402F Block 4: OPEN Type 5 Data: 74000F Block 5: OPEN Type 5 Data: 33403F Block 6: OPEN Type 5 Data: 70403F Block 7: OPEN Type 5 Data: 70604F Block 8: OPEN Type 5 Data: 71402F Block 9: OPEN Type 5 Data: 71030F Block 10: OPEN Type 5 Data: 71606F Block 11: OPEN Type 5 Data: 73002F Block 12: OPEN Type 5 Data: 72207F Block 13: OPEN Type 5 Data: 74807F Block 14: OPEN Type 5 Data: 73404F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: spansion chip
Member: 267822 Status: Online Sonork: 100.1605213 Thanks: 451
| Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359390003583798 SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! ------ Operation: UNLOCK V1 Date: 10-03-2008 Time: 17:18:03 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 359390003583798 SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-115_359390003583798_Locked_Keycnt_0_Fbuscnt_0__V_0 6.10_16-02-07_RM-115_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2080100000000000 Block 1: OPEN Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
| | #12 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Rawalpindi-->Pakistan
Member: 315789 Status: Offline Sonork: 1596456 Thanks: 541
| hmmmmmmmmmmmmmmmmmm good work man N80 no prob for me But N75 not unlocked by me with bb5 box br mughalG |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| >>> CU515 unlocked SUCCESS <<< | keaelite | LG | 12 | 05-15-2009 19:44 |
| >>> A411 unlock successfully <<< | keaelite | UST Pro II | 6 | 07-30-2008 06:06 |
| >>> V3E unlocked successfully <<< | keaelite | Smart-Clip | 3 | 06-02-2008 09:01 |
| >>> L760v unlocked successfully <<< | keaelite | UST Pro II | 4 | 05-21-2008 07:14 |
| <<< N75 Unlocked Successfully >>> | Raja Com. | MT-BOX | 1 | 12-13-2007 10:17 |
