03-06-2008, 14:34 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | N95 Counter 3/3 10/10 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 352255017236401 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Block 2: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_352255017236401_Locked_Keycnt_3_Fbuscnt_10__V_ 06wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... ERROR: Cannot find any usable backup file Second Phone of the day having same problem .. Resetting counter of this model supported ? |
03-06-2008, 15:16 | #5 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214417 Status: Offline Thanks Meter: 21 | Well if you first read pm308 you have a backup of that area of phone. so when you get counter's full ie 3/3 10/10 you write pm308 backup and you get 0/3 0/10 so then you can try and unlock again. Understand now? |
03-08-2008, 14:24 | #9 (permalink) |
Crazy Poster Join Date: Apr 2004 Age: 56
Member: 62725 Status: Offline Thanks Meter: 0 | I have had a problem since upgrading to v4.0 nearly every time i unlock a phone it fails and sets the counter to 10 and when i write the backed up pm308 file back to the phone it still remains at 10. even thought the file clearly stated it should be 0 is there any reason for this? its starting to lose me alot of business now |
how to - Reset network lock counters (3/3 10/10) on n95 | wynYN | BB5KING | 7 | 11-24-2008 00:16 |
n95 key counters 10/10 3/3 problem | ABI-GSM | BB5KING | 3 | 11-12-2008 20:15 |
N95 8gb,6301,5700,6500s Reset counter 3/3 & 10/10 Free! | jawad8305 | Nokia Base Band 5 ( BB-5 ) | 49 | 06-17-2008 18:13 |
** BB5BOX Updates Only Here - BB5 v0.0.4.1 - 3/3 10/10 FBUS counter reset ** | MANOLE | BB5BOX | 24 | 03-29-2008 23:30 |
PLease we need update for 3/3 10/10 counters | DaWizard | BB5BOX | 1 | 02-04-2008 03:49 |
