02-14-2008, 00:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: twitter home
Member: 120893 Status: Offline Thanks Meter: 69 | N95 Probleme ------ Operation: WRITE PM 308 Date: 13-02-2008 Time: 03:20:49 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v31_05-06-07_RM-159_(c)_Nokia IMEI: 356996017141119 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v31_05-06-07_RM-159_(c)_Nokia IMEI: 356996017141119 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Block 2: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_356996017141119_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v31_05-06-07_RM-159_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-159_356996017141119_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v31_05-06-07_RM-159_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Block 2: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 02 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 02 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 0000000000000000 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
02-14-2008, 00:22 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
br RNC_EBM | |
N95 problems needs help please | SPDRACR | Nokia Hardware & Hardware Repair | 5 | 10-08-2007 20:31 |
only nokia n95 problem | ihsanali | MT-BOX | 1 | 09-10-2007 21:20 |
