Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 275861 Status: Offline Sonork: 100.111 Thanks: 168
| is the new e65 with samsung flash chip suported for unlock? hi sir just want to know that if the new e65 phones r suported for unlock ,becuase i was trying to unlock it but always get unlock fail message. or if there is another tp for it?. thx info ll be apriciated |
| | #2 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: algeria Age: 43
Member: 189532 Status: Offline Thanks: 69
| Quote:
br .... | |
| | #3 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007
Member: 588059 Status: Offline Thanks: 0
| Quote:
Check your testpoints if is made corectly (usualy need an adapter to be able to touch BGA balls), or use a good microscope and check easy testpoints by Sagem Master Team (sticky thread!). Also post a log here if you really need help. | |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: www.mobilephoneservice.ie Age: 35
Member: 599385 Status: Offline Sonork: 100.1583205 Thanks: 291
| I have problem whit the E65 cant unlock>I have try 1000......times and diferent solution nothing.......Hier is the logo Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 354832016698845 SP LOCK status: Config Key: 2600100000000000 Block 1: CLOSED Type 5 Data: 26001F Block 2: CLOSED Type 5 Data: 26001F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-208_354832016698845_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-208_354832016698845_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2600100000000000 Block 1: CLOSED Type 5 Data: 26001F Block 2: CLOSED Type 5 Data: 26001F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2600100000000000 Block 1: CLOSED Type 5 Data: 26001F Block 2: CLOSED Type 5 Data: 26001F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. I did the new TP OOOOO11OOOOOOOO3OO oooooooooooooooooooooo its looks like that? |
| | #5 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks: 76
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| please inform that firms is suported for unlock in the soft | fasternaiger | SRS (Simlock Remote Server) | 1 | 03-28-2010 21:50 |
| Which one is the fast and best and cheapest online server for unlock and rpl files? | caremobiles | The Market Feed Back | 0 | 06-25-2009 12:27 |
| Here is the new look of samsung lang info | tsarkh | Samsung Flashers, Software, Firmware. | 1 | 10-22-2008 13:37 |
| New DCT3 flasher with the support of new Flash Chips 00B000EA for exchange | xpmobile | Exchange Section | 20 | 06-13-2003 20:40 |
