11-14-2007, 22:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: uk
Member: 322130 Status: Offline Thanks Meter: 57 | nokia 5300 error Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_03.50_14-09-06_RM-146_(c)_Nokia. IMEI: 354564015134791 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries ------ Operation: UNLOCK Date: 14-11-2007 Time: 14:31:55 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_03.50_14-09-06_RM-146_(c)_Nokia. IMEI: 354564015134791 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-146_354564015134791_Locked_Keycnt_0_Fbuscnt_0__V_0 3.50_14-09-06_RM-146_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-146_354564015134791_Locked_Keycnt_0_Fbuscnt_0__V_0 3.50_14-09-06_RM-146_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... ERROR: Not suported model/version ody help this please here log |
11-14-2007, 23:01 | #2 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Kakanien Age: 55
Member: 45247 Status: Offline Thanks Meter: 49 | you can read here which versions are supported. http://www.bb5box.org/ your's is not ( like the box told you ) make update and you will be happy . |
Nokia 5300 usb flash error | realtech | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 04-16-2010 03:33 |
Nokia 5300 error syn the phone in flashing | er.shivam | Nokia Base Band 5 ( BB-5 ) | 1 | 03-19-2010 01:05 |
Nokia 5300 error flashing | realtech | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-15-2010 02:36 |
nokia 5300 flashing error | radu_adriansv | Cyclonebox | 1 | 12-03-2009 01:07 |
