10-01-2007, 17:38 | #1 (permalink) |
Freak Poster Join Date: Apr 2003 Location: Croatia - Hrvatska Age: 42
Member: 27001 Status: Offline Thanks Meter: 32 | Nokia 6288 problem ERROR on UNLOCK ! Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353xxxxxxxxxxxx SP LOCK status: Block 1: CLOSED Type 5 Data: 21901F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_353xxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... ERROR: 11160001 ERROR: 30020061 where is the problem ???? help me |
10-01-2007, 17:52 | #2 (permalink) |
Member: 27001 Status: Offline Thanks Meter: 32 | i pun GROUND to another place and then i get this eror Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353xxxxxxxxxxxx SP LOCK status: Block 1: CLOSED Type 5 Data: 21901F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_353xxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. what to do now ??? |
10-01-2007, 19:23 | #5 (permalink) |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Connect GND and testpoints EXACTLY like in this photo: http://www.bb5box.org/6280.jpg |
10-01-2007, 20:49 | #6 (permalink) | |
No Life Poster Join Date: Sep 2000
Member: 2054 Status: Offline Thanks Meter: 10 | Quote:
This happened to me too, but then I readed phone again and lock was OPEN. | |
10-02-2007, 18:17 | #8 (permalink) |
Member: 27001 Status: Offline Thanks Meter: 32 | i get this massage again , Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 353************ SP LOCK status: Block 1: CLOSED Type 5 Data: 21901F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_353***********_Locked_Keycnt_1_Fbuscnt_0__V_06. 43_30-03-07_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
10-02-2007, 21:06 | #10 (permalink) |
Member: 27001 Status: Offline Thanks Meter: 32 | look this , after 3 hours testing place for GROUND i find it and it works GREAT !!! Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 353********** SP LOCK status: Block 1: CLOSED Type 5 Data: 21901F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_353************_Locked_Keycnt_1_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 21901F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull It is olny ground problem !!! Nothing else |
Nokia 6288 wont turn on | ferdie1969 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-02-2010 04:06 |
Nokia 6288 wont turn on | ferdie1969 | Nokia Base Band 5 ( BB-5 ) | 0 | 03-02-2010 03:05 |
Nokia 6288 problem - PLEASE HELP !!!! - SOS | margaritis | Nokia Hardware & Hardware Repair | 4 | 10-08-2008 20:21 |
error on unlock 6288 spansion - cant unlock, need help! | ktele | BB5BOX | 11 | 01-17-2008 15:39 |
