11-12-2007, 19:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: ALGERIA..UK...SINGAPORE... Age: 59
Member: 2845 Status: Offline Thanks Meter: 9 | Nokia 6630!! Searching for phone... Phone found on FBUS interface Reading phone info ... Type: RM-1 Version: V_04wk47_m_v5_17-08-05_RM-1_(c)_Nokia. IMEI: 35XXXXXXXXXXXXXXXXXX SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults... Reset phone... Reset phone in TEST mode... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-1_35XXXXXXX _Locked_Keycnt_0_Fbuscnt_0__V_04wk47_m_v5_17-08-05_RM-1_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-1_35NXXXXXXXXXXX_Locked_Keycnt_0_Fbuscnt_0__V_04wk 47_m_v5_17-08-05_RM-1_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... ERROR: Not suported model/version Thanks |
..:: Nokia N91 Music plyer for Nokia 6630, 6680, 6681 ONLY::.. | Javajohn | Nokia Multimedia | 21 | 06-02-2007 14:11 |
Nokia 6630 to Nokia 6630 Music Edition | rp4you2 | Nokia Base Band 5 ( BB-5 ) | 1 | 09-20-2006 15:34 |
Nokia 6630 games to nokia 7610 | darin | Nokia Multimedia | 0 | 03-12-2006 01:49 |
I need advice on a unlocking solution for the nokia 's 6680 & Nokia 6630? | hunk4004 | n-Box | 3 | 03-03-2005 16:51 |
I need advice on a unlocking solution for the nokia 's 6680 & Nokia 6630? | hunk4004 | Twisterflasher | 8 | 03-02-2005 22:09 |
