11-22-2007, 21:48 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Caribbean
Member: 98526 Status: Offline Thanks Meter: 12 | Nokia E 65 Look this Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 354832010 SP LOCK status: Config Key: 7340400000000000 Block 1: CLOSED Type 5 Data: 73404F Block 2: CLOSED Type 5 Data: 74807F Block 3: CLOSED Type 5 Data: 21407F Block 4: CLOSED Type 5 Data: 21402F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70503F Block 7: CLOSED Type 5 Data: 74000F Block 8: CLOSED Type 5 Data: 71030F Block 9: CLOSED Type 5 Data: 71402F Block 10: CLOSED Type 5 Data: 73002F Block 11: CLOSED Type 5 Data: 732123 Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 70604F Block 14: CLOSED Type 5 Data: 71606F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-208_354832010250817_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-208_354832010250817_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7340400000000000 Block 1: CLOSED Type 5 Data: 73404F Block 2: CLOSED Type 5 Data: 74807F Block 3: CLOSED Type 5 Data: 21407F Block 4: CLOSED Type 5 Data: 21402F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70503F Block 7: CLOSED Type 5 Data: 74000F Block 8: CLOSED Type 5 Data: 71030F Block 9: CLOSED Type 5 Data: 71402F Block 10: CLOSED Type 5 Data: 73002F Block 11: CLOSED Type 5 Data: 732123 Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 70604F Block 14: CLOSED Type 5 Data: 71606F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. Can any body help me pls?? Regards |
nokia 5800 firmware unlock this model | simlock | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 04-09-2010 11:22 |
RH-65, where this? | jose miguel | MT-BOX | 1 | 04-16-2007 02:03 |
are you looking for new nokia Fbus cable,look at here!!! | boiljames | Main Sales Section | 0 | 08-31-2006 18:00 |
