11-14-2007, 09:38 | #1 (permalink) |
Insane Poster Join Date: Apr 2007
Member: 498516 Status: Offline Thanks Meter: 4 | NOKIA N 73-3 Unlock problem. i have flashed my mokia n75 to supported version for unlocking. but now after sooooooooooo many tries the set says unlock fail.please advice on this. Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815012249812 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-128_354815012249812_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-128_354815012249812_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
11-14-2007, 16:33 | #4 (permalink) |
Insane Poster Join Date: May 2005 Age: 46
Member: 149217 Status: Offline Thanks Meter: 21 | I also have this problem I cannot liberate I have 2 team and none of the 2 teams achieves me to liberate. Somebody can please help me Nokia N73 RM133 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v46.3_04-06-07_RM-133_(c)_Nokia. IMEI: 354804011573000 SP LOCK status: Config Key: 7300200000000000 Block 1: CLOSED Type 5 Data: 73002F Block 2: CLOSED Type 5 Data: 21407F Block 3: CLOSED Type 5 Data: 72207F Block 4: CLOSED Type 5 Data: 74807F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 732123 Block 7: CLOSED Type 5 Data: 74000F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_354804011573000_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v46.3_04-06-07_RM-133_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-133_354804011573000_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v46.3_04-06-07_RM-133_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7300200000000000 Block 1: CLOSED Type 5 Data: 73002F Block 2: CLOSED Type 5 Data: 21407F Block 3: CLOSED Type 5 Data: 72207F Block 4: CLOSED Type 5 Data: 74807F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 732123 Block 7: CLOSED Type 5 Data: 74000F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
nokia n 73 back light problem | sunil_1062 | Nokia Base Band 5 ( BB-5 ) | 0 | 09-03-2009 17:36 |
Nokia N 73 cloned connectivity problem | MayoMohamed | Chinese Models & Cloned Phones | 1 | 04-03-2009 16:09 |
NOKIA N75-3 unlock problem. | matrix123 | BB5BOX | 2 | 11-14-2007 12:00 |
Sagem Myc2-3 Unlocking Problem | wintop | Redbox | 4 | 05-09-2006 08:27 |
Myx-3 unlocking problem | eko | Phone Unlocking Codes & Maps | 11 | 07-29-2003 17:33 |
