02-12-2008, 22:45 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Caribbean
Member: 98526 Status: Offline Thanks Meter: 12 | Nokia N95-3 Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-160 Version: V_06wk41v38_13-08-07_RM-160_(c)_Nokia IMEI: 357676010 SP LOCK status: Config Key: 7340400023927779 Block 1: CLOSED Type 5 Data: 732123 Block 2: CLOSED Type 5 Data: 21407F Block 3: CLOSED Type 5 Data: 21402F Block 4: CLOSED Type 5 Data: 74000F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70503F Block 7: CLOSED Type 5 Data: 70604F Block 8: CLOSED Type 5 Data: 71402F Block 9: CLOSED Type 5 Data: 71030F Block 10: CLOSED Type 5 Data: 71606F Block 11: CLOSED Type 5 Data: 73002F Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 74807F Block 14: CLOSED Type 5 Data: 73404F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-160_35767601038_Locked_Keycnt_0_Fbuscnt_0__V_06wk4 1v38_13-08-07_RM-160_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-160_35767601038_Locked_Keycnt_0_Fbuscnt_0__V_06wk4 1v38_13-08-07_RM-160_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7340400023927779 Block 1: CLOSED Type 5 Data: 732123 Block 2: CLOSED Type 5 Data: 21407F Block 3: CLOSED Type 5 Data: 21402F Block 4: CLOSED Type 5 Data: 74000F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70503F Block 7: CLOSED Type 5 Data: 70604F Block 8: CLOSED Type 5 Data: 71402F Block 9: CLOSED Type 5 Data: 71030F Block 10: CLOSED Type 5 Data: 71606F Block 11: CLOSED Type 5 Data: 73002F Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 74807F Block 14: CLOSED Type 5 Data: 73404F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7340400023927779 Block 1: OPEN Type 5 Data: 732123 Block 2: OPEN Type 5 Data: 21407F Block 3: OPEN Type 5 Data: 21402F Block 4: OPEN Type 5 Data: 74000F Block 5: OPEN Type 5 Data: 33403F Block 6: OPEN Type 5 Data: 70503F Block 7: OPEN Type 5 Data: 70604F Block 8: OPEN Type 5 Data: 71402F Block 9: OPEN Type 5 Data: 71030F Block 10: OPEN Type 5 Data: 71606F Block 11: OPEN Type 5 Data: 73002F Block 12: OPEN Type 5 Data: 72207F Block 13: OPEN Type 5 Data: 74807F Block 14: OPEN Type 5 Data: 73404F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull Regards Starcell |
PLEASE help unlock nokia n95 3 network australia | mongral355 | Nokia Hardware & Hardware Repair | 0 | 01-21-2009 23:31 |
Nokia N95-3 | hisham ny | Nokia Base Band 5 ( BB-5 ) | 12 | 06-16-2008 20:52 |
Nokia N95-3 thief caught red handed...err..almost...(help please?) | John Gilmour | Nokia Base Band 5 ( BB-5 ) | 1 | 05-29-2008 13:20 |
