11-20-2007, 19:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Problem with 5300 unlock - ERROR: 11160001 Code: Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.00_27-04-07_RM-146_(c)_Nokia. IMEI: 356408019xxxx SP LOCK status: Config Key: 2400100000000000 Block 1: CLOSED Type 5 Data: 24001F Block 2: CLOSED Type 5 Data: 24001F Block 3: CLOSED Type 5 Data: 24001F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-146_35640801xxxxx_Locked_Keycnt_0_Fbuscnt_0__V_05.00_27-04-07_RM-146_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-146_356408019xxxxx_Locked_Keycnt_0_Fbuscnt_0__V_05.00_27-04-07_RM-146_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... ERROR: 11160001 ERROR: 30020034 |
11-20-2007, 19:35 | #2 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: Czech republic Age: 54
Member: 56634 Status: Offline Thanks Meter: 71 | Quote:
11-20-2007, 20:15 | #3 (permalink) | |
No Life Poster Join Date: Apr 2000 Age: 55
Member: 1246 Status: Offline Thanks Meter: 25 | Ground Quote:
11-20-2007, 20:49 | #4 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | You are doing something wrong ... To avoid such errors try to follow this advices: - fix Vbat+ and BSI clips who power the phone with some tape or anything else (is a REQUIREMENT) - connect GND in right place (near CPU or Flash memory) and try avoid moving/touching this when connect testpoints. - solder a small wire in point where you connect GND and attach GND crocodile on this is MUCH BETTER. - press push button on testpoints only when you are sure both CLK and DATA is well touched. - set an 1-2 seconds delay (in settings menu) and still use push button (this will work and avoid errors from small movements of testpoints right after pushing button) - try to NOT MOVE testpoints in any way when unlocking is performed (is only few seconds) Regards .::Ja\/\/aD::. |
Problem with 5300 | JayDi | Nokia Hardware & Hardware Repair | 2 | 09-16-2008 06:06 |
problem with 5300 | lusomaco | J.A.F. V-SPEC | 11 | 02-10-2008 02:58 |
problem with 5300 RM-146 Version: V_03.50_14-09-06_RM-146 | yecaluna21 | BB5BOX | 0 | 10-22-2007 22:14 |
Unlock Problem With 5300 (mt Pro ) | Nasmi | MT-BOX | 10 | 07-06-2007 17:51 |
