Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 11-23-2007, 21:56   #1 (permalink)
Member: 318494
Thanks Meter: 18
Exclamation problem unlock 14 blocks in a 5200b rm 181
hello team bb5 box i have 3 5200b rm 181 problem unloking this phone have 14 blocks closed i have flashing downgrade to 4.70 and uploaded to version 5.00 and the closed block
in the next tread have the log ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-174
Version: V_05.00_27-04-07_RM-174_(c)_Nokia.
IMEI: 352733016394371
SP LOCK status:
Config Key: 7300200000000000
Block 1: CLOSED Type 5 Data: 73002F
Block 2: CLOSED Type 5 Data: 21407F
Block 3: CLOSED Type 5 Data: 72207F
Block 4: CLOSED Type 5 Data: 74807F
Block 5: CLOSED Type 5 Data: 33403F
Block 6: CLOSED Type 5 Data: 732123
Block 7: CLOSED Type 5 Data: 74000F
Block 8: CLOSED Type 5 Data: 73002F
Block 9: CLOSED Type 5 Data: 21407F
Block 10: CLOSED Type 5 Data: 72207F
Block 11: CLOSED Type 5 Data: 74807F
Block 12: CLOSED Type 5 Data: 33403F
Block 13: CLOSED Type 5 Data: 732123
Block 14: CLOSED Type 5 Data: 74000F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Reset phone in TEST mode ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-174_352733016394371_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-174_352733016394371_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 55
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 55
Try number: 7
Response byte: 55
Try number: 8
Response byte: 55
Try number: 9
Response byte: 55
Try number: 10
Response byte: 55
Unlock fail. Please try again.
please help me in this problem ....
regarts ....
Old 11-23-2007, 23:30   #2 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
For 5200b (RM-81)
only thsi version can be unlocked :
5200b (RM-181) – Flash Chip SEC xxxxxxxx-ATD
V_03.92_13-10-06_RM-181_(c)_Nokia.
V_04.71_28-02-07_RM-181_(c)_Nokia.
V_05.00_27-04-07_RM-181_(c)_Nokia.
5200b (RM-181) – Flash Chip SEC xxxxxxxx-ATB
V_03.70_22-09-06_RM-174_(c)_Nokia.
and pls chek if your mobile :
5200b (RM-181)–Flash Chip SEC xxxxxxxx-ATB or 5200b (RM-181)–Flash Chip SEC xxxxxxxx-ATD
Old 11-23-2007, 23:56   #3 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
Thanks Meter: 2,476
Try to downgrade it and make ok TP thats all other option is u disconect GND
BR,
Tito Millo
Old 11-24-2007, 00:33   #4 (permalink)
japunlock's Avatar
Member: 87396
Thanks Meter: 64
where do you connect gnd crocodile?
are you sure you are on right points of board?
Old 11-27-2007, 17:40   #5 (permalink)
Member: 318494
Thanks Meter: 18
this 5200b is a –Flash Chip SEC xxxxxxxx-ATB and this phone have conect the clable gnd ( cocodrile) to the armor in the phone
Old 12-02-2007, 16:21   #6 (permalink)
kelvinator's Avatar
Member: 262145
Sonork: 100.1668642
Thanks Meter: 98
Please upgrade to latest version and everything ok.
Regards.
Old 12-02-2007, 16:59   #7 (permalink)
melgsm's Avatar
Member: 629039
Sonork: 100.112945
Thanks Meter: 847
plz check if u change the write with the left boint
5200b RM-181 Dead After USB flash HELP!!! Panthereitor J.A.F. By Jafsupport.com 2 02-18-2008 20:26
5200b RM-181 V4.72 PROBLEM UNLOCK ELGOAT MT-BOX 8 01-22-2008 10:58
Nokia 5200b RM-181 - Flash file needed alvaroc MT-BOX 1 12-20-2007 12:57
Need Flash v5.00 for 5200b rm-181 marcosfranklin MT-BOX 6 11-06-2007 01:41
5200b rm-181 without log????? selfbox MT-BOX 0 09-18-2007 14:25
Page generated in 0.15604 seconds with 9 queries
