10-01-2007, 09:22 | #47 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 353483 Status: Offline Thanks Meter: 0 | 1. Can we have a more detailed infomation for the second modification? first, a more detailed or clear picture for the modification. second, what is the normal solding temperature for the PCB like this. (sorry, I do not have any much knowledge on this area). 2. do we need to use ACP-12x after we have fixed the LM7805 stabilizer IC ? |
10-01-2007, 18:05 | #48 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
10-01-2007, 19:42 | #50 (permalink) | |
On Anode pin of diode you will solder output of LM7805 (search for PDF datasheet). On the hole left alone (where was Anode of diode) solder input pin of LM7805 On the -(minus) pin of C26 solder Ground of LM7805 (check datasheet) After this modification, no more use ACP-12x to supply BB5 Box. Use an adapter who give output somwhere between 6 and 9 volts. Plus in the middle of connector. If your adapter don't fit/match in BB5 Box ACP connector, cut the connector from your ACP-12x and wire this to your adapter. For soldering use any cheap soldering iron or soldering station. If you can set temperature for your soldering equipament, put somwhere 400-450. Or much better, find a friend who know something about hardware, soldering, electronics, show him this photo, messages and he will know what to do. | |
10-01-2007, 20:51 | #51 (permalink) |
Member: 353483 Status: Offline Thanks Meter: 0 | Thanks BB5box.org it is much clear. Oh, just before you post. I asked my reseller about it. and he suggest that do not modify the box unless I got phone unlocking fault. but I am not sure, what kind of problem will be caused by the power supply issue? (sorry, just got the box. And have not got the microspe. So only unlocked few phones yet. not sure what the power supply problem wil be. ) |
10-01-2007, 21:06 | #52 (permalink) | |
10-01-2007, 23:52 | #53 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 38
Member: 38980 Status: Offline Sonork: 100.84054 Thanks Meter: 124 | i am not shure my regulator is good. i should mesure 5.0V on the left side- left side of the 2 diodes??? ( 0.85V...., but red diode is good) (my acp-12 is 7.5V !!!, interresting. its original nokia....)1 |
10-02-2007, 14:11 | #54 (permalink) | |
Member: 353483 Status: Offline Thanks Meter: 0 | Quote:
still between 500 ~ 1000 mA?? | |
10-02-2007, 18:58 | #55 (permalink) |
No Life Poster Join Date: Jun 2004 Location: sure...not at heaven... Age: 56
Member: 67494 Status: Offline Thanks Meter: 71 | my last questions ,for now if i make the modify whit 5 v stabilizer ic,i can use the acp12 whe i have buy??? if i make the modify the box work exactly like before if used WHITOUT any ext power??? tnks |
10-02-2007, 23:26 | #57 (permalink) | |
If box is used without external power, box work like before. Modification is on external power path circuit. | |
10-03-2007, 07:33 | #58 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | Quote:
Also..I have not seen the diagram so obviously i cannot know this but are there 100nF capacitors on the bb5 box allready ? Correct way is to do 100nF cap's on either side of the regulator, otherwise it sometimes does crazy things with the output voltage or even short circuit's .. Twisterfan | |
10-03-2007, 09:26 | #59 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Kenya
Member: 70343 Status: Offline Thanks Meter: 38 | Quote:
Hi all, Has anyone tried this solution? What is the output of this charger? Is it stable? It would certainly be better than modifying the box. | |
10-03-2007, 10:00 | #60 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 196046 Status: Offline Thanks Meter: 3 | callme thick if u like but pleas eexplain in good english --- 1 do all boxes need some modification ---2 mine is working ok with acp12x nokia charger do i need ot do any thing only fone i get errors on is 6280 ---this chip ic thingy needs installed if we return to reseller will get new one or replacemet as no way am im fitting any chip to my box my self .---and if u cant offer some one to do it then will we be refunded the price of box as if its faulty with out it then surely it is not good and should be retrned for refund under statutory rights here in uk dont mean to be funny but mine is working at minute ect so unsure wat last 6 pages are fafling on about |
Here You Find All Nokia Assemble And Disassembly Videos For Bb5 Box Enjoy. | rajan nishchal | BB5BOX | 125 | 04-09-2011 22:03 |
7Pin 24 In 1 Cable Set Compatible For BB5King Activation For BB5 Box / JAF | IPMART | ipmart WebShop | 0 | 11-12-2008 12:20 |
2 5200 dead using original acp-12e charger please help bb5 box team | gurnek66@hotmai | BB5BOX | 3 | 10-01-2007 19:41 |
< Post here all phones unlocked successfully by BB5 box > | kin88 | BB5BOX | 5 | 09-25-2007 17:02 |
