03-02-2008, 08:08 | #1 (permalink) |
Junior Member Join Date: Feb 2008
Member: 713342 Status: Offline Thanks Meter: 0 | still can't unlock 6085 5.03 spansion with 4.0,what's wrong?help Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_05.03_09-08-07_RM-198_(c)_Nokia. IMEI: 358061017917006 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 02-03-2008 Time: 17:33:00 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_05.03_09-08-07_RM-198_(c)_Nokia. IMEI: 358061017917006 SP LOCK status: Config Key: 5050100058056920 Block 1: CLOSED Type 5 Data: 50501F Block 2: CLOSED Type 5 Data: 50501F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! ------ Operation: UNLOCK V1 Date: 02-03-2008 Time: 17:34:10 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_05.03_09-08-07_RM-198_(c)_Nokia. IMEI: 358061017917006 SP LOCK status: Config Key: 5050100058056920 Block 1: CLOSED Type 5 Data: 50501F Block 2: CLOSED Type 5 Data: 50501F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-198_358061017917006_Locked_Keycnt_0_Fbuscnt_0__V_0 5.03_09-08-07_RM-198_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020111 |
03-02-2008, 10:30 | #2 (permalink) |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | You have response byte 55. Make a search on forum for this problem. 0x55 means Phone is completely loosing connection. Wrong GND location or bad cables. We have tested 6085 with both small and big Spansion chips and working well. Try also to check what exactly selection you made for flash chip, acording with what is written on your flash chip ... |
03-02-2008, 10:48 | #3 (permalink) | |
Member: 713342 Status: Offline Thanks Meter: 0 | Quote:
03-04-2008, 04:58 | #4 (permalink) | |
Freak Poster Join Date: Nov 2003 Location: Australia
Member: 44593 Status: Offline Thanks Meter: 7 | response byte 08 Quote:
Please help with 6085 response byte 08. i did unlock 5 fons 3 without any problem and other 2 always comes up with unlock failed and response byte:08 please tell me what did i do wrong thanx and br | |
03-09-2008, 21:04 | #6 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | 6085 Unlock Pls Check Ur Clk Tp , If It Spark Then Cant Unlock, Its Better ( For Me) To Use A Sharp Needle With Clk Tp , Then Try To Unlock And I M Sure U Will Be Able At First Time ... This Problem I Have Faced A Few Days Ago With A N73 And 6086 , Then I Tried With A Needle With Clk And Everything Is Fine ... |
bb5king can't unlock 6131....new small spansion | dimon | BB5KING for (BB5BOX) | 2 | 11-05-2008 11:57 |
BB5_v0.0.2.3 Still Can't Unlock N71 | black_dregon | BB5BOX | 8 | 10-06-2007 18:23 |
I still can't unlock 6300 with SEC ATD flash | Szymon | BB5BOX | 15 | 09-27-2007 08:32 |
S55 with old cable - what's wrong? | tommiki | E-Gold Based Phones | 0 | 10-19-2003 21:58 |
3650 can't unlock after 5 time wrong entered | Siemens man | WD2 & APE (Symbian Phones) | 2 | 09-18-2003 11:44 |
