01-19-2008, 01:02 | #1 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 550056 Status: Offline Thanks Meter: 11 | succefull unlock Nokia 5300b Rm-147 v 5.02 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-147 Version: V_05.02_05-06-07_RM-147_(c)_Nokia. IMEI:************************ SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310310 Block 11: CLOSED Type 5 Data: 310580 Block 12: CLOSED Type 5 Data: 310660 Block 13: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-146_***************xx_Locked_Keycnt_0_Fbuscnt_0__V _05.02_05-06-07_RM-147_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3102000000000000 Block 1: OPEN Type 5 Data: 310160 Block 2: OPEN Type 5 Data: 310200 Block 3: OPEN Type 5 Data: 310210 Block 4: OPEN Type 5 Data: 310220 Block 5: OPEN Type 5 Data: 310230 Block 6: OPEN Type 5 Data: 310240 Block 7: OPEN Type 5 Data: 310250 Block 8: OPEN Type 5 Data: 310260 Block 9: OPEN Type 5 Data: 310270 Block 10: OPEN Type 5 Data: 310310 Block 11: OPEN Type 5 Data: 310580 Block 12: OPEN Type 5 Data: 310660 Block 13: OPEN Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
unlock rogers nokia 5300b rm-147 v5.1 | mobowireless | J.A.F. V-SPEC | 1 | 08-13-2008 10:20 |
5300b RM-147 and 5300b RM-146 | Linkz | J.A.F. V-SPEC | 29 | 07-21-2008 12:30 |
urgent nokia 5300b rm 147 v4.70 or v4.71 flash file | wiliam | Nokia Base Band 5 ( BB-5 ) | 0 | 08-02-2007 11:06 |
