10-26-2007, 16:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: slovenia Age: 48
Member: 18028 Status: Offline Thanks Meter: 20 | n95 problems ------ Operation: UNLOCK Date: 26-10-2007 Time: 17:11:16 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 352255017913231 SP LOCK status: Config Key: 2934000000000000 Block 1: CLOSED Type 5 Data: 29340F Block 2: CLOSED Type 5 Data: 29340F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_352255017913231_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-159_352255017913231_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2934000000000000 Block 1: CLOSED Type 5 Data: 29340F Block 2: CLOSED Type 5 Data: 29340F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries ERROR: 11120001 ERROR: 30020051 than yust disconect all usb devices and camera from phone because n95 must have a little more power to restart between local and test mode. so 2 n95 unlock succesfull! ------ Operation: UNLOCK Date: 26-10-2007 Time: 17:11:51 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 352255017913231 SP LOCK status: Config Key: 2934000000000000 Block 1: CLOSED Type 5 Data: 29340F Block 2: CLOSED Type 5 Data: 29340F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Skip autobackup of PM 308 Autobackup file: RM-159_352255017913231_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-159_352255017913231_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2934000000000000 Block 1: CLOSED Type 5 Data: 29340F Block 2: CLOSED Type 5 Data: 29340F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2934000000000000 Block 1: OPEN Type 5 Data: 29340F Block 2: OPEN Type 5 Data: 29340F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull ------ Operation: UNLOCK Date: 26-10-2007 Time: 17:06:40 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v31_05-06-07_RM-159_(c)_Nokia IMEI: 352255017049572 SP LOCK status: Config Key: 2934000000000000 Block 1: CLOSED Type 5 Data: 29340F Block 2: CLOSED Type 5 Data: 29340F Keyboard wrong codes counter: 2 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_352255017049572_Locked_Keycnt_2_Fbuscnt_0__V_0 6wk41v31_05-06-07_RM-159_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-159_352255017049572_Locked_Keycnt_2_Fbuscnt_0__V_0 6wk41v31_05-06-07_RM-159_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2934000000000000 Block 1: CLOSED Type 5 Data: 29340F Block 2: CLOSED Type 5 Data: 29340F Keyboard wrong codes counter: 2 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2934000000000000 Block 1: OPEN Type 5 Data: 29340F Block 2: OPEN Type 5 Data: 29340F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-27-2007, 16:09 | #4 (permalink) |
Member: 18028 Status: Offline Thanks Meter: 20 | i unlock more than 10 n95 without problem but with this 2 make me crazy.so i put original charger from nokia mesure voltage ok but still after while nokia cant be detected so i put external power suplly problem same. |
10-27-2007, 16:40 | #5 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Use a good power supply 1amp 6v and put LM7805 inside box and don't need to make some trick again. http://www.bb5box.org/Safety_Mod.jpg |
10-28-2007, 15:41 | #6 (permalink) |
Member: 18028 Status: Offline Thanks Meter: 20 | belive me i try all but nothing next time in unlocking n95 i will mesure with osciloskop so i will know why? p.s i think like pbb mcu inside box are very sensitivy to power. i will tell you next time |
N95 problems needs help please | SPDRACR | Nokia Hardware & Hardware Repair | 5 | 10-08-2007 20:31 |
only nokia n95 problem | ihsanali | MT-BOX | 1 | 09-10-2007 21:20 |
