Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 02-02-2008, 14:34   #1 (permalink)
Member: 695399
Exclamation Trouble Unlocking 6300 With BB5 Box - Nokia 6300 Using Test Point Jig- Please Help :)
Hi Guys
I would appreciate some help as im having trouble unlocking a 6300.
I have the BB5 Box setup using the V.16 firmeware and a testpoint jig.
Every time I try to use the software to access the phone I get the following error -
I have the box connected via the RJ45 cable and the test point jig, see below -
If any one can answer these questions it would be appreciated -
There is a small button on the jig pcb, do I need to press this at any point?
There are two small on / off switches on the pcb, currently both set to on. Is this correct?
Thanks in advance!
Old 02-02-2008, 21:05   #2 (permalink)
Member: 685949
dont you use the testpoint jig, you have no need for it as this testpoint is very easy.
Old 02-02-2008, 22:06   #3 (permalink)
Member: 695399
I am trying to use the testpoint jig yes. It seems to be making correct contact too but the software just seems to come up with the same error message. I have also tried another nokia model + testpoint jig with the same software and it does not seem to want to work. Do you know what the switches on the jig pcb are for?
Thanks for your help
Old 02-02-2008, 22:10   #4 (permalink)
Member: 685949
Mate Please Dont Use The Testpoint Jig.
Old 02-02-2008, 23:01   #5 (permalink)
James-R's Avatar
Member: 104911
Thanks Meter: 42
maybe the phone is barred
Old 02-03-2008, 01:40   #6 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
Switch on phone , if u want to unlock it .
Old 02-04-2008, 01:10   #7 (permalink)
Member: 3811
Thanks Meter: 24
test points on this model are not to hard to see please study the test point pictures on support site you do not need a test point jig for this model please try without jig mobile will unlock first time .............
Old 02-04-2008, 09:23   #8 (permalink)
Registered User
Member: 234917
Thanks Meter: 160
It is quicker to unlock using the normal test point cable than using this adapter. In any case you should learn how to do it properly as this is one of the easiest phones to unlock - what will you do when you need to unlock an e65? You need to press the power button before you can read the phone. I don't think you will get much help here on how to use these tp adapters as I don't think anyone uses them.
Ronan
6086 unlock fail with bb5 box Bao Tran BB5BOX 22 12-25-2007 01:06
help unlokcing 6300 with BB5 box mc_denz BB5BOX 1 12-06-2007 18:54
5300b ver 4.51 unlocked susecfull with BB5 Box.....100000% Bao Tran BB5BOX 0 10-15-2007 08:10
I Lost My A1000 Test Point Tp Please Help sullivan2002 Motorola P2k 0 03-11-2007 04:26
nec 606 test point problem PLEASE HELP ali-g-string NEC 12 07-14-2004 10:39
Page generated in 0.17040 seconds with 10 queries
