11-02-2007, 21:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Mexico Age: 51
Member: 124842 Status: Offline Thanks Meter: 11 | N95 error 11200001 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 356962015382790 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Block 3: CLOSED Type 5 Data: 23433F Block 4: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes ERROR: 11200001 ERROR: 30020033 |
11-02-2007, 22:08 | #3 (permalink) |
Member: 124842 Status: Offline Thanks Meter: 11 | oooopppsss Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 356962xxx382790 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Block 3: CLOSED Type 5 Data: 23433F Block 4: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_356962015382790_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-159_3569620xxxxx82790_Locked_Keycnt_0_Fbuscnt_0__V _06wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Block 3: CLOSED Type 5 Data: 23433F Block 4: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Block 3: OPEN Type 5 Data: 23433F Block 4: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thhxxxss |
11-08-2007, 20:25 | #4 (permalink) |
Crazy Poster Join Date: Jan 2005 Location: Lauro de Freitas - Bahia - Brasil Age: 42
Member: 110997 Status: Offline Thanks Meter: 8 | I removed camera from PCB and the error continue... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 352255019848641 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Block 2: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes ERROR: 11200001 ERROR: 30020033 |
error 11200001/30020033 | The_Gorr | BB5BOX | 9 | 01-28-2008 08:02 |
Error 11200001 - Whats this??? | unterulmen | BB5BOX | 2 | 10-25-2007 21:21 |
N95 Error write | xiumeng | Nokia Base Band 5 ( BB-5 ) | 4 | 09-09-2007 06:09 |
nokla n95 error in connection | hamid123 | Infinity-Box | 2 | 09-04-2007 13:26 |
