09-20-2007, 13:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: gsm market Age: 35
Member: 222481 Status: Offline Thanks Meter: 30 | 6280 testpoints i got one 6280 today and its tp was F-U-C-K-E-D by a uid user with solder on rap ic , well here only two peoples are doing bb5 unlocking , me i use dk,mtpro and now bb5 box , but the other one using uid ,m so it must be his job any other tp for this phone model br ryaz |
09-20-2007, 15:08 | #3 (permalink) |
Member: 222481 Status: Offline Thanks Meter: 30 | yes phone powering all ok. only the pins on rap are not visible all destroyed seems by soldering any other points any other ways to unlock? br ryaz |
09-20-2007, 15:28 | #4 (permalink) |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | You can clean RAP pins. Using alcohool and/or ultrasonic bath method. Best will be to put alcohol in ultrasonic bath. This will disolve soldering paste and ultrasonig will remove from there. |
09-20-2007, 22:52 | #10 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Palestine Age: 40
Member: 103945 Status: Offline Sonork: 100.112828 Thanks Meter: 355 | who destroy tp pins you can desolder ic flash and solder wire then solder falsh and used it how to know which point clk and data this simple in 6280 you can show desolder ic flash in manual uid or get another phone and test tp pin on rap and in point ic flash by multimeter may be help you only by this method now i think |
09-20-2007, 23:08 | #11 (permalink) |
Member: 103945 Status: Offline Sonork: 100.112828 Thanks Meter: 355 | for 6280/6288 this make easy to understand who know alternative tp download and see pic but this you should prof for solder and desolder ic flash download enjoy |
09-21-2007, 02:20 | #12 (permalink) |
Member: 222481 Status: Offline Thanks Meter: 30 | yes but as the market already fuc-ked up , you will ask the people for 20 euro for this they will see it high , better i return it to customer br ryaz |
09-21-2007, 09:38 | #13 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Absolutely right, for desolder flash and put wire and resolder and unlock you need to loose a lot of time whit risk to destroy the phone, better you give back to customer and relax whit coffee. |
11-08-2007, 17:23 | #14 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Mauritius Age: 47
Member: 7482 Status: Offline Thanks Meter: 24 | perhaps that person is not that skillful to be able to desolder and resolder the RAP .. that's why he returned to customer. :-) funny little guy :-) |
has anyone tried the 6280 testpoint adapter??? | alexmkdMAFIA | Nokia Base Band 5 ( BB-5 ) | 0 | 07-17-2008 01:20 |
@BB5Box, can you change 6280 testpoint to pin27 instead of 24? | SubTen | BB5BOX | 17 | 01-31-2008 01:31 |
need guide for 6280 testpoint. | mentari | BB5BOX | 0 | 09-25-2007 16:23 |
how to connect testpoints to 6280 phone? | tmunot | MT-BOX | 44 | 06-30-2007 10:39 |
6280 switched off when testpoints connected | Maratello | MT-BOX | 10 | 06-13-2007 18:32 |
