12-20-2007, 08:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: bestncheap Age: 43
Member: 19785 Status: Offline Thanks Meter: 1,242 | Find RX TX, Read Flash, Format FSS, with MCTOOL 1. How To Find RX TX GND on the Phone - Phonetype : MTK - Speed : Super Fast - Press Auto Find Pin Out - Press and Hold Power Button until find rx tx and GND This the logs [ 13:41:31 ] [--- Operation Started ---] [ 13:41:31 ] Detecting power pins... [ 13:41:34 ] Detected GND : 2 [ 13:41:35 ] Searching for pinout... [ 13:41:48 ] Pinout detected OK! [ 13:41:48 ] RX : 7 TX : 9 [ 13:41:48 ] Writing settings to Box... [ 13:41:50 ] Settings has been written OK! [ 13:41:50 ] [--- Operation Successful! ---] 2. HOW to Read Flash With MCTOOL - Auto Find Pin Out - Go to MTK TAB - Read Flash This the logs [ 13:42:02 ] [--- Operation Started ---] [ 13:42:03 ] Press and keep power ON button... [ 13:42:11 ] Phone detected : MTK CPU [ 13:42:11 ] Preparing phone for boot... [ 13:42:13 ] Release power ON button now! [ 13:42:13 ] CPU Platform : 8A02-6226 [ 13:42:14 ] Loading bootloader... [ 13:42:18 ] Bootloader loaded OK! [ 13:42:18 ] Getting flash chip details... [ 13:42:19 ] Flash chip ID : 0001227E [22202200] [ 13:42:19 ] Chip Name : AMD AM49PDL127-S71PL127J [ 13:42:19 ] Flash chip size : [ 0x01000000 - 16MB ] [ 13:42:19 ] Chip block (0x00) : 1000 * 1000 [ 13:42:19 ] Setting parameters... [ 13:42:21 ] Initializing phone`s RAM... [ 13:42:22 ] RAM initialize OK! [ 13:42:22 ] Reading flash memory... [ 13:46:01 ] Flash memory read OK! [ 13:46:01 ] [--- Operation Successful! ---] 3. How To Solve insert sim card and phone restart - Auto Find Pin Out - Go to MTK TAB - Press Unlock/Repair/Format FFS This the Logs [ 14:09:41 ] [--- Operation Started ---] [ 14:09:41 ] Press and keep power ON button... [ 14:09:43 ] Phone detected : MTK CPU [ 14:09:43 ] Preparing phone for boot... [ 14:09:45 ] Release power ON button now! [ 14:09:45 ] CPU Platform : 8A02-6226 [ 14:09:46 ] Loading bootloader... [ 14:09:50 ] Bootloader loaded OK! [ 14:09:50 ] Getting flash chip details... [ 14:09:52 ] Flash chip ID : 0001227E [22202200] [ 14:09:52 ] Chip Name : AMD AM49PDL127-S71PL127J [ 14:09:52 ] Flash chip size : [ 0x01000000 - 16MB ] [ 14:09:52 ] Chip block (0x00) : 1000 * 1000 [ 14:09:52 ] Setting parameters... [ 14:09:52 ] Fromatting FFS, please wait... [ 14:10:11 ] FFS Format OK! [ 14:10:11 ] [--- Operation Successful! ---] BR BNC Last edited by SiRoYa; 12-21-2007 at 16:49. |
The Following 3 Users Say Thank You to bestncheap For This Useful Post: |
12-20-2007, 08:23 | #2 (permalink) |
Registered User Join Date: Apr 2004 Location: paradise Age: 45
Member: 60836 Status: Offline Thanks Meter: 4 | How To Find RX TX GND on the Phone with wich cable phone is connected first time (all pin connected or what ) |
The Following User Says Thank You to nouri23 For This Useful Post: |
12-20-2007, 08:56 | #3 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | @nouri23 To find rx tx gnd Just chose the right cables... Plug in the crocodile connetor to phone + and - then just press autofind and press power on BR BnC |
The Following User Says Thank You to bestncheap For This Useful Post: |
12-21-2007, 09:54 | #5 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | Try Today Nokia N73CHINA Restart when insert sim card 1. Read Pinout [ 15:00:11 ] [--- Operation Started ---] [ 15:00:11 ] Detecting power pins... [ 15:00:14 ] Detected GND : 1,4 [ 15:00:15 ] Searching for pinout... [ 15:00:26 ] Pinout detected OK! [ 15:00:26 ] RX : 11 TX : 12 [ 15:00:26 ] Writing settings to Box... [ 15:00:29 ] Settings has been written OK! [ 15:00:29 ] [--- Operation Successful! ---] 2. Better make backup before do any operation, this backup operation [ 15:07:54 ] [--- Operation Started ---] [ 15:07:55 ] Press and keep power ON button... [ 15:07:56 ] Phone detected : MTK CPU [ 15:07:56 ] Preparing phone for boot... [ 15:07:59 ] Release power ON button now! [ 15:07:59 ] CPU Platform : 8A02-6226 [ 15:08:00 ] Loading bootloader... [ 15:08:03 ] Bootloader loaded OK! [ 15:08:03 ] Getting flash chip details... [ 15:08:05 ] Flash chip ID : 00EC257E [25082501] [ 15:08:05 ] Chip Name : SAMSUNG K5L2931CAM [ 15:08:05 ] Flash chip size : [ 0x01000000 - 16MB ] [ 15:08:05 ] Chip block (0x00) : 8 * 2000 [ 15:08:05 ] Chip block (0x01) : FE * 10000 [ 15:08:05 ] Chip block (0x02) : 8 * 2000 [ 15:08:05 ] Setting parameters... [ 15:08:06 ] Initializing phone`s RAM... [ 15:08:08 ] RAM initialize OK! [ 15:08:08 ] Reading flash memory... [ 15:11:33 ] Flash memory read OK! [ 15:11:33 ] [--- Operation Successful! ---] 3. Format FFS for solving restart problem.. [ 15:12:08 ] [--- Operation Started ---] [ 15:12:09 ] Press and keep power ON button... [ 15:12:11 ] Phone detected : MTK CPU [ 15:12:11 ] Preparing phone for boot... [ 15:12:14 ] Release power ON button now! [ 15:12:14 ] CPU Platform : 8A02-6226 [ 15:12:14 ] Loading bootloader... [ 15:12:18 ] Bootloader loaded OK! [ 15:12:18 ] Getting flash chip details... [ 15:12:20 ] Flash chip ID : 00000000 [EC257E25] [ 15:12:20 ] Chip Name : SAMSUNG K5L2931CAM [ 15:12:20 ] Flash chip size : [ 0x01000000 - 16MB ] [ 15:12:20 ] Chip block (0x00) : 8 * 2000 [ 15:12:20 ] Chip block (0x01) : FE * 10000 [ 15:12:20 ] Chip block (0x02) : 8 * 2000 [ 15:12:20 ] Setting parameters... [ 15:12:20 ] Fromatting FFS, please wait... [ 15:12:33 ] FFS Format OK! [ 15:12:33 ] [--- Operation Successful! ---] br bnc |
12-21-2007, 20:53 | #7 (permalink) |
No Life Poster Join Date: Sep 2002 Location: India
Member: 15238 Status: Offline Thanks Meter: 128 | HERE primary question - The cable with two crocodile connectors should be inserted at BOX end OR at the far cable's end {here respective phone cable} ?? BECAUSE it is a female female type cable !! Both the ends of cable can be FIT at male socket {BOX out} !! RESISTOR removed BUT still it cant find GND pin of any phone. WHY ?? BR |
12-22-2007, 08:20 | #9 (permalink) | |
Member: 19785 Status: Offline Thanks Meter: 1,242 | Quote:
1. Connect Crocodile red to Positif phone, and Black to Negatif Phone. 2. Press Auto Find Pin Out (before press this make sure u have press power on at the phone) 3. Waiting... and pin out will detected... If still have problem.. please fell free to post in here.. will be grathefull help u.. BR BnC | |
12-22-2007, 08:24 | #10 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | sorry forgot one thing Put the cable write MC-T-014 (HDR26 M to M) to the box. and the other site for plug in cables (eg:MC-T-009 IP-L18A) so the converter(in this case i call converter) one side with MC-T-014 (HDR26 M to M) plug in to the box.. and another side to phone cables (eg:MC-T-009 IP-L18A) hope can imagine what i write.. BR BnC |
12-22-2007, 12:10 | #11 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | Again Test Today NOKIA N80 RH-37 (Mobile Technology/StereoSound) Cables : 2 x 6 = 12pin Problem : phone restart Read Pin out [ 18:01:41 ] [--- Operation Started ---] [ 18:01:41 ] Detecting power pins... [ 18:01:44 ] Detected GND : 7,9 [ 18:01:45 ] Searching for pinout... [ 18:01:55 ] Pinout detected OK! [ 18:01:55 ] RX : 5 TX : 8 [ 18:01:55 ] Writing settings to Box... [ 18:01:57 ] Settings has been written OK! [ 18:01:57 ] [--- Operation Successful! ---] Format FFS [ 18:05:20 ] [--- Operation Started ---] [ 18:05:21 ] Press and keep power ON button... [ 18:05:22 ] Phone detected : MTK CPU [ 18:05:22 ] Preparing phone for boot... [ 18:05:25 ] Release power ON button now! [ 18:05:25 ] CPU Platform : 8A02-6226 [ 18:05:25 ] Loading bootloader... [ 18:05:29 ] Bootloader loaded OK! [ 18:05:29 ] Getting flash chip details... [ 18:05:31 ] Flash chip ID : 00980049 [00000000] [ 18:05:31 ] Chip Name : TOSHIBA TV00578002DABD [ 18:05:31 ] Flash chip size : [ 0x01000000 - 16MB ] [ 18:05:31 ] Chip block (0x00) : 1000 * 1000 [ 18:05:31 ] Setting parameters... [ 18:05:31 ] Fromatting FFS, please wait... [ 18:05:37 ] FFS Format OK! [ 18:05:37 ] [--- Operation Successful! ---] |
12-23-2007, 16:16 | #14 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | can we alive the dead Spreadtrum CPU fones...(not only Spreadtrum also..all) using this MC-TOOL... if yes means....procedure... thanks sir... |
The Following User Says Thank You to harim_1981 For This Useful Post: |
12-27-2007, 21:53 | #15 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | it support language edıtor like multibox or infinity? backup format normal bin or special ? |
The Following User Says Thank You to BesTCooL For This Useful Post: |
How to find RX TX pins at chinesse phones with Infinity | ka2 | Chinese Models & Cloned Phones | 0 | 02-17-2009 17:48 |
how to find rx tx with fin finder Sony-Ericsson-J132 | fraz12345 | Infinity-Box | 1 | 02-05-2009 15:22 |
HOW TO FIND RX/TX WITH ipHONE ON PAD?? | frooze_angel | PadFinder box | 11 | 07-21-2008 11:46 |
mc cant find rx,tx | vinay_sharma | MC-Tool | 6 | 02-04-2008 09:22 |
auto find rx tx | G F | MC-Tool | 0 | 01-08-2008 03:05 |
