07-07-2008, 15:23 | #1 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 38962 Status: Offline Thanks Meter: 3 | f480 Phone freeze code I tried entering it using the #7465625*638* but it says freeze code incorrect. I have put the imei for verify but I would like to know if there is any other special way this is a touch screen phone btw. Samsung 351872020350374 Samsung F480 |
07-07-2008, 17:17 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: AWS Cloud
Member: 395349 Status: Offline Thanks Meter: 509 | F480 : 351872020350374 Unlock Code : #7465625*638*07973502# Unfreeze Code : #7465625*638*83713637# You need to Original SIM Card to enter Unfreeze Code. |
07-09-2008, 13:23 | #8 (permalink) |
Freak Poster Join Date: May 2008
Member: 769746 Status: Offline Thanks Meter: 4 | Samsung - Return for Service (Help) Someone please clarify if a Samsung handset and has entered an incorrect code too many times and the message comes up saying "Return for Service" is this the same as Phone Freeze? If so does someone know the correct procedure for entering the unfreeze code you get from UnlockBase into a Samsung U600? I have a customer who entered the unlock code provided by unlockbase and he said thatit has locked out his handset and it is now displaying the message above. He followed the correct instructions for input too as far as I can tell. I have asked him to enter the unfreeze code too but this doesn't seem to be working on the handset so I wanted to check the correct method of input for a Samsung U600. Thanks |
07-10-2008, 15:57 | #9 (permalink) |
Member: 38962 Status: Offline Thanks Meter: 3 | check video http://www.youtube.com/watch?v=wYAHlOJj1qE |
07-13-2008, 17:58 | #12 (permalink) |
Insane Poster Join Date: May 2004
Member: 66860 Status: Offline Thanks Meter: 7 | I've got the same problem with Samsung F480. After entering unlock code #7465625*638*79497184# phone display message "Deactivation Failed". I've sent codes for verify and they were verified before monent but came the same codes.... It seems that there is some bigger problem with unlocking F480 phones... What should I do now? |
07-14-2008, 14:20 | #13 (permalink) |
Member: 66860 Status: Offline Thanks Meter: 7 | Now when I switch on phone with unaccepted simcard, phone displays "Phone freeze contact network provider". I've entered then accepted SIMCARD, switched on phone and then entered unfeeze code #7465625*638*93606420#. Phone displayed "This phone is freeze. Deactivation failed" What should I do now? |
07-22-2008, 16:20 | #14 (permalink) |
Junior Member Join Date: Jul 2008 Location: France
Member: 811029 Status: Offline Thanks Meter: 2 | Hi, Exactly the same problem. The unfreeze code that came from Samsung seems to be a right code but unable to be accepted by the phone. Put an accepted sim card, enter dial mode, enter code and the the message "this phone is freeze phone desactivation fail". I begin to believe that there is a problem in the manipulation of the phone when trying to unlock or unfreeze it. Tomorrow, I'm going to take the phone to a phone shop specialist in unlocking. If any news, I will post it on this topic. |
The Following User Says Thank You to jmalloza For This Useful Post: |
Samsung F480 Phone freeze | ::.::RAMJAN::.:: | Gsmfather The Wholesale Unlocking Database | 10 | 06-01-2014 20:22 |
Samsung F480 Phone Freeze! | Saff | NSPRO | 6 | 02-28-2011 03:55 |
unlock erro F480 phone Freeze | longgiang81 | Easy-Unlocker | 5 | 03-13-2009 22:59 |
F480 Phone Freeze can not unlock! | hoangtruongson | UST Pro II | 3 | 11-03-2008 08:30 |
F480 phone freeze :(( | elektronat | Easy-Unlocker | 2 | 08-30-2008 00:01 |
