Chinese Cocktail All info about all chinese phones supported by Multi-box and Multi-box LITE is here. Please use this section for talks about china made phones |
01-27-2008, 01:56 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 587478 Status: Offline Thanks Meter: 0 | B889 dual sim problem Mine has corrupted IMEI and multi-box doesn't recognize it correctly and reparing IMEI doesn't work. If i try to change the IMEI for the secondary CPU the phone dosen't work correctly anymore (master side is dead also). |
01-27-2008, 13:25 | #3 (permalink) | |
Member: 587478 Status: Offline Thanks Meter: 0 | Quote:
If i change the IMEI it still shows one IMEI on the phone and there is wierd problems with locks. Master CPU log: Press and hold power on button...OK Loading Boot.......OK CPU ID: 6226-8A NOR Flash ID:0001227E - 2000 - AMD AM49PDL127BH Size:16Mb !!! Unknown Firmware version !!! Please read full flash backup and send it to [email protected] Detecting EEPROM data... Version: MAUI.05C.W06.16 Branch: 05C MTK26_05C_MASTER- - - IMEI: 3510*********xx Phone locks status: User lock: 1122 - OPEN Code2: 1234 Code3: 5678 Code4: 3344 Code5: 0000 IMSI: 082*************** Reading calibration data...OK Ready... Slave CPU log: Press and hold power on button...OK Loading Boot.......OK CPU ID: 6205-8B NOR Flash ID:0001227E - 1A01 - AMD S71GL032R3_T Size:4Mb FW vers: n6500 114 DAYO_NEP_06B_PMJ Detecting EEPROM data... WARNING! Automatic EEPROM detection method is used! Please read phone Flash backup before start of any operation Version: I.06B.W07.20.MP.V7 Branch: 227 DAYO_NEP_06B_PMJ- - - IMEI: ;:0:?6?2?1>1:95 Phone locks status: User lock: - ERROR! Code2: 90 Code3: Code4: 05 Code5: IMSI: 077*************** Reading calibration data...OK Cant create backup file C:\Program Files\Multibox\Chinese_cocktail_MTKCST_Tool\Backup \;:0:?6?2?1>1:95_260108_03202 | |
01-28-2008, 10:03 | #4 (permalink) | |
No Life Poster Join Date: Mar 2001 Age: 43
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
01-29-2008, 17:10 | #5 (permalink) |
Member: 587478 Status: Offline Thanks Meter: 0 | I noticed that you updated the software and added secondary MCU firmware. It still complains for the primary MCU that it doesn't recognize the firmware, did you do any change for this one ? Also the IMEI change for secondary MCU doesn't work properly, it makes the change but it still display only on IMEI on the phone and secondary MCU is offline (primary firmware doesn't find the second SIM at all). |
02-17-2008, 20:02 | #6 (permalink) |
Member: 587478 Status: Offline Thanks Meter: 0 | Just updated to newest coctail, but still it complains i have unknown firmware version! Here's the log: Press and hold power on button...OK Loading Boot.......OK CPU ID: 6226-8A NOR Flash ID:0001227E - 2000 - AMD AM49PDL127BH Size:16Mb !!! Unknown Firmware version !!! Please read full flash backup and send it to [email protected] Detecting EEPROM data... Version: MAUI.05C.W06.16 Branch: 05C MTK26_05C_MASTER- - - IMEI: 35************x Phone locks status: User lock: 1122 - OPEN Code2: 1234 Code3: 5678 Code4: 3344 Code5: IMSI: 082944503200743612 Reading calibration data...OK Ready... I also downloaded firmware for the slave CPU (from your support area), but the software didin't accept it. Here's the log: Ready... Profile file not exist! Default file will be created Press and hold power on button...OK Loading Boot.......OK CPU ID: 6205-8B NOR Flash ID:0001227E - 1A01 - AMD S71GL032R3_T Size:4Mb !!! Unknown Firmware version !!! Please read full flash backup and send it to [email protected] Detecting EEPROM data... Phone system data not found Please make phone Flash backup and rewrite phone EEPROM part Loading MCU file... Fw Info: b889 DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN Ready... Please ensure that selected firmware size and flash size is same! Preparing Flash image... Error! Incorrect Start or/and Length! Incorrect file signature! Please select correct file Here are the flash backup files if you didin't get them earlier Master 6226 flash: http://rapidshare.com/files/92600915...clean.bkp.html Slave 6205 flash: http://rapidshare.com/files/92625308...-full.bkp.html |
02-19-2008, 18:28 | #7 (permalink) | |
2. Did you update sig file also? | |
Need pinout b889 dual sim | tsm2318 | Chinese Models & Cloned Phones | 2 | 03-02-2009 00:37 |
n95 slide dual sim problem | f164 | Infinity-Box | 1 | 08-24-2008 21:39 |
dual sim problem solved | c_ahmad79 | Infinity-Box | 2 | 08-14-2008 18:27 |
anycool t828i dual sim problem? | saidgoren | Infinity-Box | 3 | 08-06-2008 00:30 |
Panasonic GD87 Dual Sim problem | saznat | Panasonic | 0 | 10-26-2004 23:10 |
