02-04-2009, 23:25 | #5 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: root
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | Quote:
well, then it might the cable (wrong resistor - search board) try do open JAF sw, and put phone in local mode (steady), then close it, keep phone connected to jaf box, and open bb5_jaf_unlocker . if ur cable is good, this method will work. br | |
02-05-2009, 15:35 | #7 (permalink) |
No Life Poster Join Date: Jul 2005 Location: I'm back to business
Member: 184793 Status: Offline Sonork: 100.1574609 Thanks Meter: 45 | 1st install corect driver (Nokia_Connectivity_Cable_Driver) then connect fone in pc suite mode ,that all good luck Br LordMen007 |
02-05-2009, 16:10 | #9 (permalink) | |
Junior Member Join Date: Jan 2008 Location: Brazil
Member: 673888 Status: Offline Thanks Meter: 0 | Quote:
well, then it might the cable (wrong resistor - search board) not need log to unlock it's not? | |
02-07-2009, 21:07 | #11 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Pakistan Peshawar Age: 35
Member: 242264 Status: Offline Sonork: 100.1582011 Thanks Meter: 33 | use 8.2 k resister instead of 7.5 in cable and change the 2 ohm resister into 1 ohm resister in jaf box i did this and i always have local mode after few restarts |
02-11-2009, 13:35 | #12 (permalink) |
No Life Poster Join Date: Jul 2008 Location: UK
Member: 819396 Status: Offline Thanks Meter: 113 | hi, i just unlocked an N95 8GB had the same problem with the USB prompt appear on screen. i just connected and disconnected the FBUS cable till it entered local mode as it just kept on starting to offline mode previously. Finally got to local mode and unlocked within seconds. very impressed with how easy it was to unlock after got the phone into local mode. hope this helps anyone who has the same prob |
Help me to unlocK N95 8GB...??? | manyosa | Nokia Base Band 5 ( BB-5 ) | 2 | 05-02-2009 14:41 |
plz help me with unlock t639 | ufs-4 | UST Pro II | 7 | 05-16-2008 07:52 |
plz help me with unlock c75 | ufs-4 | FuriousGold | 2 | 04-04-2008 11:49 |
