10-21-2008, 10:22 | #2 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 528831 Status: Offline Thanks Meter: 18 | 6300 unlocking problem Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359812011069049 SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_359812011069049_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Unlock fail. Please try again. |
10-21-2008, 10:27 | #3 (permalink) |
Registered User Join Date: Aug 2007 Location: bohol philippines Age: 42
Member: 572549 Status: Offline Thanks Meter: 175 | Config Key: FFFFFFFFFFFFFFFF try check this one you need RPL calcualtion.. SP data Corrupted if you have back up just restore it by clicking write back up.. |
6300 unlock problem | Mr Twitch | MT-BOX | 5 | 10-01-2007 09:42 |
6300 unlocking problem. | mobile_2003 | MT-BOX | 2 | 09-22-2007 11:42 |
6300 unlock problem REVISIOn=D | ozeracar | MT-BOX | 27 | 09-03-2007 12:22 |
6300 unlock problem???? | anowar_47 | MT-BOX | 7 | 08-04-2007 20:39 |
6300 unlock problem | ALVYDAS007 | Nokia Base Band 5 ( BB-5 ) | 1 | 07-05-2007 09:33 |
