About problems with JAF and phones Because of strange design of JAF, there is a lots of problems with entering phones to TEST or LOCAL mode. Some problem can be with JAF cables. On some cables there is resistor on BSI with 5K (TEST mode) or 7,5K(LOCAL mode). So, you have to check those values using multimeter. For LOCAL mode USE 8-8,2 K instead of 7,5k Also for N95, N95 8g there is NOT enough POWER from USB, be sure that USB port from your PC have HIGH current and stabile 5v. Also replace resistor of 2ohm iside of JAF flasher with resistor of 1 ohm or less! Also, there is strange thing with n95 8g. While other models come into LOCAL or TEST mode very fast 1-2 sec, on N95 8g proces is something like this: It turn display ON 1sec,turn display OFF 1sec, again turn display ON few sec and then shows "LOCAL MODE, etc". BUT, if you don't have stabile power on USB it will again turn OFF!!! and proces is repeted. So DO NOT start to unlock any phone BEFORE you have stabile message on phone that is phone in LOCAL or TEST mode!!! Same problem can occure after exiting phone from flash mode to enter again LOCAL or TEST mode to write password that card was calculated. But since pass is stored on PC,reconnect JAF, reconnect phone, restart unlocker and wait for stabile LOCAL or TEST mode on phone and click again on UNLOCK button. |
I was waited for this exact explanation for ages. :) Thx |
i suggested to users allrady to use the JAF UNIVERSAL FBUS CABLE this cable have all resistors ouside placed, the pins are easy to replace and it works for 99% of the phones. Same problem with JAF interface. Since JAF mcu was extracted from Narry and Davor before 3 years, since that time all china is producing jaf hard ware. Most of our reseller order ONLY PKEY-V with smartcard, all others they are doing by themselfs. Also the jaf platform itself, it was design before 3 years, i think it will be good time to change the interface now. The fact is, jaf is working stable if the box is made according to the schematic and if the cables are okay. B.R., Raskal |
(becoz of your post i'll purchase JAF UNIVERSAL FBUS CABLE AS I'VE PB WITH MY CABLES and i didn t know if universal fbus is good or the same thing...but now i know) for example My p-key is thomas and I bought a pkey no more, and reseller never tell if there s diferences, and finally have to pay 59e for update and others 49e,...so to see clear, think stikey will info about diferences will be good PS: even my pkey is thomas...I got chance...Thanks for somebody from your team. WBR, |
about the reseller and difference, who is your reseller? B.R., Raskal |
resellers, there's a lot and each time i buy something, i select. jaf +`pkey bought from Font Telecom www.imeis.com and as i learned leccion, usim bought from Manole directly, and activation of bb5box too.... I know u r doing ur best....and i'm stisfied with all tools i bought from your team : ubl, usb smart, bb5box, jaf... PS:I'm still waiting my kanguroo...:D WBR, |
can we more info what phones are supported????donr n95 8gb without any problems |
for cables is better using Universal fbus cables.. u can use any cable.. by GPG , by JAF, By IPMART, by GSM CABLES, BY MTK, By Huier, By Sutton, many more.. just same can use that.. For N95 or N82 switch resistor to bsi 7,5k or 10k.. For this phone need add more power to cable.. (like dejan said power from usb not enough) so phone can not 100% local mode Solution is by add 4,3 volt till 4,5 volt to SFBUS at VCC Wire/(usualy is red) and gnd put any ground in the cable or pcb (cause some cable dont have gnd cables, just have vcc and bsi) I test this with UFC www.unifbuscable.com by GPG.. 100% work.. Just add from power 4,3volt till 4,5 volt to UFC cables.. and then sure 100% phone will show LOCAL MODE!! (i think also can do by other factory made universal fbus cables) CMIIW BR BnC |
thanks dejan for help. i open my jaf box and change resistor to 1ohm. i check whit jaf after check and after flash phone enter in local mode whiteout problem. before modification i always have problem whit local mode (n95 n82). ;) |
can show picture of which resistor inside JAF box to change to 10omh? thank you gsmuk |
jaf box have only 1 resistor near usb connector (very easy to find) and need 1 ohm not 10. and modify cables too i put 8k resistor on bsi and all work beter. |
1 Attachment(s) Here a photo where the resistor is located. ;) |
Okay, but have you try it? Best Wishes, Susan |
off course i try and all is ok. i flash today many phones dct4 bb5 and all is ok. i don't have locked n95 for try. before i change this resistor i always have problem whit n95 flashing he don't enter in local mode (allays power off when enter local mode). after change phone stay in local mode whiteout problem i flash and make factory default too. |
