07-27-2008, 04:34 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 730882 Status: Offline Thanks Meter: 4 | Bb5 Unlock 6280 Down Grade Help Please I Try To Unlock 6280 By Bb5 Box , When I Try To Info The Phone , I Got The Text Said Please Select Flash Chip Type, Then I Press Ok It Said Model Version Not Support For Fbus Counter Reset , Please Upgrade Or Downgrade This Model/version Is Supported For Unlock, Because I Just Buy The Box So This Is The First Time Please Help Me , Thanks In Advance here the log Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.40_20-12-05_RM-78_(c)_Nokia IMEI: 357926000148507 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! This model/version IS SUPPORTED for UNLOCK. |
07-27-2008, 05:21 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | your in wrong section m8, your logs show bb5box not dk box.anyway your version is supported for unlock but version is not supported for key code counts.if you have back up pm write it back & unlock again.if you don't have back up then flash your phone with supported version for keycode count coz your logs show 3/3 to 10/10.so that you could unlock your phone br |
The Following User Says Thank You to shawgsm For This Useful Post: |
07-27-2008, 05:28 | #3 (permalink) | |
Member: 730882 Status: Offline Thanks Meter: 4 | Quote:
I did not try unlock yet , version is not supported for key code counts what that mean can you explain more please I am very new , flash your phone with supported version for keycode count coz your logs show 3/3 to 10/10.so that you could unlock your phone , so what verion is support for keycode please help me thank your very much , I am in midle or fire please | |
07-27-2008, 05:50 | #4 (permalink) |
Member: 51453 Status: Offline Thanks Meter: 729 | flash your phone iwth version 6.10 or lower that support keycode counts.then unlock it make sure you have scope so that it will not be hard for you to see test point br |
07-27-2008, 05:51 | #5 (permalink) | |
hi sir can you please tell me where is support for BB5 box , thank you and please tell me what version is support for keycode count .thank you very much for your kind of help | |
The Following User Says Thank You to chess12 For This Useful Post: |
07-27-2008, 06:05 | #7 (permalink) |
Member: 51453 Status: Offline Thanks Meter: 729 | yes you can use jaf or any box that support bb5 flashing.after unlock no need to flash it back. br |
07-27-2008, 06:38 | #8 (permalink) | |
sory to bother you 1 more time , how do I know select FLASH CHIP TYPE FOR ANY PHONE WHEN I WILL UNLOCK WHEN INFO THE PHONE COME UP WITH SMALL TEST BOARD SAID PLEASE SELECT FLASH CHIP TYPE , THANKS AGAIN FOR YOUR VERY HELPFULL | |
bb5 unlock sesver down.. | kadekrudi | Universalbox | 4 | 05-29-2009 19:20 |
bb5 unlock 6280 tp damaged unlock % 100 ok | turkgsmteam | MT-BOX | 7 | 01-18-2008 08:56 |
IF ANYBODY UNLOCKED 6280 WITH SECxxxxxETA chipset, PLEASE POST HERE | chowdary | BB5BOX | 75 | 10-20-2007 01:09 |
Unlock 6280 ! Who can help? | Cuongkame.Com | Nokia Base Band 5 ( BB-5 ) | 0 | 09-04-2007 13:35 |
