Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5 Box by D.K.
Old 03-16-2013, 00:24   #1 (permalink)
Member: 1894625
How to use e71 blank pmm.fpsx with phoenix to fix e71 phone that won't boot up
My e71 wont boot up I found the following thread http://forum.gsmhosting.com/vbb/f421...art-up-676532/ ... with the solution I need but I do not know how to use the blank pmm file with phoenix, could someone please tell me how to correctly use the blank pmm with phoenix, whenever I load it into phoenix it gives me the following error and tells me to try again.
Here's the symptom and solution on the above mentioned thread and at the bottom the error I recieve after using blank pmm
This is the solution for the E71 which shows the following Symptoms...
Phone does not start up when pressing power key. When pressing the power key notification light and display backlight wake up. Vibra makes one jog. Phone will take 230 mA but nothing else happens. After 30 seconds phone will power off. You can update phone software but it doesn't help anything. Phone doesn't start to test mode...
Solution..
Flash the Phone using the attached PMM erase file...
Then Flash it with latest data pakage..
Please help me figure out how to make this work.
File Type: zip E71_blank_504KB_pmm_10.zip (930 Bytes, 647 views)
Old 03-16-2013, 00:25   #2 (permalink)
Member: 1894625
Here's the output log the phoenix gives me with the error near the bottom
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 14592 bytes
Secondary boot loaded
Loading update server code: 2080457 bytes
Update server loaded
Asic CMT: Verifying communication to device...
Flashing SingleAsic device...
Asic CMT: Start programming 111790 KB...
Asic CMT: Erasing rm346_501.21.001_prd.c00
Asic CMT: Erasing area 1...
Asic CMT: Erasing area 2...
Asic CMT: Erasing area 3...
Asic CMT: Partitioning rm346_501.21.001_prd.c00
Asic CMT: Partitioning area 1...
Asic CMT: Erasing rm346_501.21.001_prd.v20
Asic CMT: Erasing rm346_501.21.001.50U
Asic CMT: Erasing RM346_ENO_0741.10_08wk42.a36.fpsx
Asic CMT: Erasing leevi_erase_y_drive.fpsx
Asic CMT: Programming rm346_501.21.001_prd.c00
Asic CMT: Programming 0%
Asic CMT: Programming 2%
Asic CMT: Programming 4%
Asic CMT: Programming 6%
Asic CMT: Programming 8%
Asic CMT: Programming 10%
Asic CMT: Programming 12%
Asic CMT: Programming 14%
Asic CMT: Programming 16%
Asic CMT: Programming 18%
Asic CMT: Programming 20%
Asic CMT: Programming 22%
Asic CMT: Programming 24%
Asic CMT: Programming 26%
Asic CMT: Programming 28%
Asic CMT: Programming 30%
Asic CMT: Programming 32%
Asic CMT: Programming 34%
Asic CMT: Programming 36%
Asic CMT: Programming 38%
Asic CMT: Programming 40%
Asic CMT: Programming 42%
Asic CMT: Programming 44%
Asic CMT: Programming 46%
Asic CMT: Programming 48%
Asic CMT: Programming 50%
Asic CMT: Programming 52%
Asic CMT: Programming 54%
Asic CMT: Programming 56%
Asic CMT: Programming 58%
Asic CMT: Programming 60%
Asic CMT: Programming rm346_501.21.001_prd.v20
Asic CMT: Programming 62%
Asic CMT: Programming 64%
Asic CMT: Programming 66%
Asic CMT: Programming 68%
Asic CMT: Programming 70%
Asic CMT: Programming 72%
Asic CMT: Programming 74%
Asic CMT: Programming 76%
Asic CMT: Programming 78%
Asic CMT: Programming 80%
Asic CMT: Programming 82%
Asic CMT: Programming E71_blank_504KB_pmm_10.fpsx
ADL LDR: Resending Prepare for Write Partition Request....
ADL LDR: Error writing partition ID 0x0000000A to TargetAddress 0x00000000, Size 0x00020000
Asic CMT: ERROR Programming E71_blank_504KB_pmm_10.fpsx Block 0. Unable to continue flashing.
Starting to recover the phone
Recoverying phone
Initializing
Asic CMT: Error in sending data from E71_blank_504KB_pmm_10.fpsx.
Unable to flash phone 0x84012283
The Following User Says Thank You to spx118 For This Useful Post:
Page generated in 0.12722 seconds with 9 queries
