05-30-2008, 09:00 | #1 (permalink) |
Insane Poster Join Date: Jul 2005 Age: 53
Member: 164388 Status: Offline Thanks Meter: 7 | n-76 RM-128 unlock ok but not unlock Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 3548150122***XX SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 2 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-128_3548150122******_Locked_Keycnt_2_Fbuscnt_10__V _06wk15v37_08-03-07_RM-128_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 5555555555555555 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Phone unlocked succesfull |
05-30-2008, 09:35 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Always Here Age: 37
Member: 333494 Status: Offline Sonork: 100.1607053 Thanks Meter: 190 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 3548150122***XX SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 2 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-128_3548150122******_Locked_Keycnt_2_Fbuscnt_10__V _06wk15v37_08-03-07_RM-128_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 5555555555555555 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Phone unlocked succesfull open your eays??? and i don``t know if this modell supportet for unlock???? |
05-30-2008, 09:46 | #6 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Bogatic , RS Age: 56
Member: 4395 Status: Offline Thanks Meter: 159 | Quote:
unlock ok but not unlocked | charletan | SETool2 | 1 | 02-12-2009 18:05 |
Zte-125 Unlock Ok.........but Not Unlock | pavitter | Infinity-Box | 1 | 05-08-2008 13:57 |
Vodafone Unlock Ok.........but Not Unlock | pavitter | Infinity-Box | 3 | 05-08-2008 10:09 |
A1000 on soft unlock ok, but not unlocked | kimo59 | Smart-Clip | 0 | 03-26-2007 12:29 |
MYX2-2 unlock ok but not unlocked | zeozea | Redbox | 2 | 12-26-2005 13:50 |
