05-24-2008, 14:24 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Azerbaijan, Baku
Member: 254961 Status: Offline Thanks Meter: 24 | New 6300 flash type not unlockable? |
06-09-2008, 16:10 | #5 (permalink) | |
Major Poster Join Date: Sep 2005 Location: Belarus Age: 43
Member: 185792 Status: Offline Thanks Meter: 34 | Quote:
Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.70_24-01-07_RM-217_(c)_Nokia. IMEI: 353510020669199 SP LOCK status: Config Key: 2620700000000000 Block 1: CLOSED Type 5 Data: 262074 Block 2: CLOSED Type 5 Data: 262075 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_353510020669199_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 2620700000000000 Block 1: CLOSED Type 5 Data: 262074 Block 2: CLOSED Type 5 Data: 262075 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. | |
C1100 new flash type ???? can unlock | deha | LG | 1 | 02-22-2006 09:24 |
B-2000 flash type not supported | nik | VygisToolbox | 2 | 05-20-2005 11:21 |
replacing new IC flash type of 3210 | edoy | Nokia Hardware & Hardware Repair | 3 | 07-25-2003 02:49 |
Flash type not suported | sloper | Nokia Hardware & Hardware Repair | 8 | 05-18-2003 21:13 |
Flash type not supported | .::AkhavanGSM::. | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 09-08-2002 08:58 |
