Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5 Box by D.K.
Old 04-04-2009, 16:07   #1 (permalink)
Member: 770274
Thanks Meter: 15
Nokia N79 unlock
hi evry1
i have nokia N79 4 unlock ..so do ihve to use usb cabal ya f bus ???
The Following User Says Thank You to munir0410 For This Useful Post:
Old 04-05-2009, 01:05   #2 (permalink)
haiminhk15_sc's Avatar
Member: 152057
Sonork: 100.1582385
Thanks Meter: 220
Originally Posted by munir0410 View Post
hi evry1
U can use both of them
Note: If u want to use usb cable, u need install TRK app on the phone. U can refer to guide of Mr Dejan
"For those who dont have JAF unlocker and have only USB cable, please folow the instructions:
Part one - Install TRK Apps
1. You must have Nokia data suit because Dejan soft using driver from data suit and to install TRK file
2. After this you need to install s60_3_1_app_trk_2_8_6.sisx or s60_3_1_app_trk_2_8_9.sisx . Which file need to install depending of phone software. First is for older second is for newer phones .You don't need to know joust try to install and one of this must pass instillation.
3. If you have installed data suit and phone connected with usb cable to PC, just click twice on s60_3_1_app_trk_2_8_6.sis or s60_3_1_app_trk_2_8_9.sis and installation will start automatically. Confirm all message on phone.
4. Find in your phne where is application installed and start the TRK application. Example in N81 8gb path is MENU/APPLICATION/TRK in some phone MENU/APPLICATION/MY OWN/TRK
5. When you start you will get message "activate blutooth in offline mode" press key NO.
6. Press OPTION button and select SETTINGS and in CONNECTION field change to USB and press button BACK.
7. Close TRK App and start again
8. You must have screen like this. I copy this from Nokia N81 8GB:
Welcome to TRK for Symbian OS
Status: Connected
PDD: NONE
LDD:EUSBC
CSY:ECACM
Port number :1
Baud rate: 115200
Part two- unlocking phone.
1. Connect phone to PC with usb cable and start TRK application.
2. Start BB5_TRK_unlocker.exe
3. Clik on button "Read Phone" and you will get phone info on screen.
4. For safety reason click on button " Make Backup". If something goes wrong to have backup for phone.
5. Click on button " SP Unlock" . Wait until on screen not have message " If everything is OK,...."
6. On phone press key for OPTION select with cursor "Hello World" and confirm .
7. In few seconds you will have UNLOCKED PHONE !!!!! "
Good Luck
The Following User Says Thank You to haiminhk15_sc For This Useful Post:
Old 04-05-2009, 13:48   #3 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
always refer to stickey and read info..coz all is in forum
http://forum.gsmhosting.com/vbb/showthread.php?t=615998
BR,
The Following User Says Thank You to boucettay For This Useful Post:
How to unlock nokia n79 Lutfur Cyclonebox 6 01-10-2010 09:32
Haw unlock nokia n79? krystian139 Nokia Base Band 5 ( BB-5 ) 0 11-06-2009 22:23
nokia n79 unlocking problem bittubansal JAF No Tp Unlocker by Cinek 0 03-19-2009 07:42
NOKIA N79 after flash dead gsmlife Infinity-Box 4 09-04-2007 19:21
Chinese Nokia N79 Cable Pinout maplegsm Infinity-Box 6 07-29-2007 14:27
Page generated in 0.15235 seconds with 9 queries
