10-23-2008, 08:24 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: netherlands Age: 52
Member: 511649 Status: Offline Thanks Meter: 33 | other problem have the phone on pc suite and hello world app open but only see white screen when press unlock i get unable to connect to trk instal trk on phone and run it but i have done this already |
10-23-2008, 08:31 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | First you need to open the TRK app in your phone, then option--> setting--> connection, sellect UBS"" then the unlocker program will say something like " if everything ok, will continue" then you will see the Hello World and option sellect "Hello" then should be good good luck |
10-23-2008, 09:21 | #4 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Around the world Age: 56
Member: 106484 Status: Offline Thanks Meter: 400 | Read this http://forum.gsmhosting.com/vbb/showthread.php?t=615998 After reading, If you have still problem contact me on skype or sonork. Boban |
10-23-2008, 09:35 | #6 (permalink) |
Member: 20639 Status: Offline Thanks Meter: 233 | Hi Boban, i have 4 nokia 6120c, 2 of them is unlocked fine!! the orther 2 is cannot change TRK connection to USB, always stay on "Bluetooth" why?? is it need the older TRK ver.? thannks |
10-23-2008, 09:57 | #7 (permalink) |
Member: 20639 Status: Offline Thanks Meter: 233 | I solved the problem now. make sure the phone 6120c is not Ver 3.70, need to undate in order to change the TRK coonection setting to USB. thank Teams |
Motorola a925 flash ,flash mode,software and other problems | wiking155 | Motorola P2k | 0 | 12-17-2005 19:07 |
Camera and other Problems In NOKIA 6600... | atin_garg2005 | Nokia Multimedia | 2 | 12-14-2005 16:08 |
C30 Phone Failure ---> solution with other problems | virtuatech | NON Siemens Brand (ODM Phones) | 9 | 09-04-2001 22:48 |
