11-15-2008, 23:42 | #8 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: GSMinators LAND Age: 40
Member: 661523 Status: Offline Thanks Meter: 205 | Quote:
I got the same error a couple of times and then when i where pressing and forcing the on/off button all went ok. If you see an error and you lose one credit so probably the unlock code has been calculated anyway and you can unlock your phone. That's what happend to me. I did get 3 different errors in the beggining but then all went ok. Before i wrote the unlock code to phone i wrote backup to phone and flashed it. After each try, check if there has been any code calculated even if you get any errors. That's how i unlocked N95 8gb today. Hope you will have luck with it, if not we have to wait for an update for stable new Rapido unlocking! | |
11-16-2008, 09:34 | #9 (permalink) |
Member: 661523 Status: Offline Thanks Meter: 205 | http://forum.gsmhosting.com/vbb/show...19&postcount=1 Here is dejans post again about how to unlock n95 8gb etc. br |
11-16-2008, 10:04 | #10 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: Melbourne , AUS Age: 47
Member: 40451 Status: Offline Sonork: 100.1580450 Thanks Meter: 73 | Quote:
Im using N95 cable , phone goes to local . Reading values and after press unlock i got same error.so you recon to make a change in cable as dejan describe ??? Cable wchich im using came with a box. So I recon is a good quality cuz never ever had anny issues. B.R Jerry | |
11-16-2008, 10:46 | #13 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Philippines
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | unlocking using ufc is just like banana ketsup... |
The Following User Says Thank You to mamo_mogon03 For This Useful Post: |
how to unlock n95 8gb in mx-key | fonegadgets2 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-13-2010 05:44 |
how to unlock n95 8gb with mt | ZIYAAD STRYKER | MT-BOX | 9 | 03-08-2009 22:23 |
How to unlock N95 8gb using J.A.F | krishanfernando | Nokia Base Band 5 ( BB-5 ) | 7 | 12-28-2008 23:29 |
How to unlock n95 8gb | alishahlondon | Universalbox | 3 | 12-14-2008 09:36 |
How to unlock N95 8gb ??? | Olegas | Nokia Base Band 5 ( BB-5 ) | 2 | 11-17-2008 17:36 |
