Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5 Box by D.K.
Old 05-08-2008, 02:50   #1 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 190
TP (data connection) damaged
@hi all..,
i try to unlock 6151 but nothing .. see picture the data connection is damaged any solution ?? any other place to put DATA cable TP
thank you
Old 05-08-2008, 04:02   #2 (permalink)
Member: 190492
Thanks Meter: 190
PS : when i do testpoint into program TPs Ok then this message appeared : NOT ALLOWED
Old 05-08-2008, 04:11   #3 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
use other box with different testpoint, hint: advance
Old 05-08-2008, 04:23   #4 (permalink)
Member: 190492
Thanks Meter: 190
thank you for reply...,but
My question plz is : TP's ARE NOT THE SAME ??, for exemple i work with advance BOX BB5 TP with MT-BOX
THANK YOU
Old 05-08-2008, 05:01   #5 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
sorry mixed up with 6280 ad1 ad0 ad8, 3 different tp, maybe soon they support the same for 6151 too.
Old 05-17-2008, 21:37   #6 (permalink)
azanduu's Avatar
Member: 764029
Thanks Meter: 84
if tp is damaged than try with UB direct unlock takes 100logs
the only solution yet
Old 05-18-2008, 03:27   #7 (permalink)
elkawasmy's Avatar
Member: 113200
Sonork: 100.1573773
Thanks Meter: 87
try to make TP wire shorter thats 100% will help u
try and post result
BR,
Elkawasmy
Old 05-18-2008, 03:33   #8 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
ub server working again? I thought nokia security hole stopped some weeks ago!
Old 05-18-2008, 12:41   #9 (permalink)
Member: 190492
Thanks Meter: 190
@azanduu, thank you but i don't think server ub work .
@mrfixit , i agree with you about ub ....
PS : i think with rpl solved problem , m sure(tp damaged)
errer in infitybox data is damaged mounir0020 Infinity-Box 5 02-28-2013 23:56
Please Help! Can I Recover Data From Damaged Sim Card? jeffarens Sim Cloning and Scaning 15 11-14-2011 17:36
w510 tp 1 resistor damage CHAGUA Smart-Clip 2 11-10-2007 19:17
6280 TP data damaged rutar MT-BOX 3 09-21-2007 20:06
how to recover data from damage mmc HUM Nokia Hardware & Hardware Repair 0 05-26-2007 01:50
Page generated in 0.18150 seconds with 10 queries
