03-28-2009, 23:12 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Age: 50
Member: 19126 Status: Offline Thanks Meter: 35 | Writing error - phone is locked but log is missing - is the refound possible? The question is regarding credit return? Is it possible - I'll try next time with 4,5 V connected to the VCC. I can send my Pkey info pass and login, Phone imei etc. Regards Sebastian Last edited by siewa26; 03-28-2009 at 23:16. Reason: errors edit |
03-28-2009, 23:24 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iPhone Age: 46
Member: 599385 Status: Offline Sonork: 100.1583205 Thanks Meter: 82 | You shut have the password in you pc for that phone....There is folder password check there...Conect again your phone and press unlock and shut be ok. |
The Following User Says Thank You to mobile-phone-service For This Useful Post: |
03-29-2009, 01:14 | #3 (permalink) |
Member: 19126 Status: Offline Thanks Meter: 35 | Correct - one more idea - because I was trying with UFC universal cables - and it didn't want to put phone into the local mode permanently (tested on all BSI Resistor settings). I used a trick - set a resistor value to 3.3 and connect an extra "Super Adapter 7.5kOhm (which I used to use with some other Fbus cables) of course 4,6 V from power supply connected to the VCC and GND - and it worked BTW you can use FBUS from regular N95: Just take off the upper part, which won't fit into the battery holder from N95 8Gb - it also may need extra resistor 7,5k ohm on BSI line (I recommend Super Adapter 7,5kOhm for lazy people) and of course extra power supply. |
7210c cs done consumed 20 credits but now the phone is locked to sp | adaki_vishal | Universalbox | 1 | 11-30-2009 13:33 |
All Locks is opened but phone is locked on Z530i | JAVA Good | Cruiser Suite | 8 | 11-26-2006 18:38 |
The Phone SE still Locked But BYE BYE 3 Logs | flechazo | Twisterflasher | 2 | 03-03-2005 22:19 |
Unlock code is working but the phone is still locked!!! | The Beast | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-23-2005 20:35 |
