Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
Member: 200475 Status: Offline Thanks: 6
| 6085 version 4.26 can be unlocked Hi FYI I have a 6085 with version 4.26 but I don't have to upgrade it. I can unlock it but I am using the modified cable. see below details _______________________ Powering the phone... Reading... MCU SW version: V 04.26 16-03-07 RM-198 (c) Nokia. HW version: 1402 PCI version: RFIC version: 17211721 DSP version: pb06w14v42.1 PPM version: V 04.26 16-03-07 RM-198 (c) Nokia. T Retu version: 32 Tahvo version: 53 Content Pack version: Content: t V 04.26 16-03-07 RM-198 (c) Nokia. Production serial number: DCJ726548 Product code: 0515894 Module code: Basic production code: 0537008 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358061015125685 IMEI spare to net: 3A 85 60 01 51 21 65 08 IMEI SV to net: 33 85 60 01 51 21 65 18 F6 LOCK STATUS: CONFIG KEY: 5050100058056920 Provider: Telstra Mobile Comms;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50501F Block 2: Lock 1: CLOSED -> Lock Data: 50501F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-198.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0515894 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__05.03.mcusw.bin PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__05.03.ppm_t CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__05.03.image_opv_telstra APE Variant file: NONE Languages in ppm: English,Vietnamese,Tagalog,Chinese S,Chinese T Done! Backup simlock data first... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\RM-198_358061015125685_04.26_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 5050100058056920 Provider: Telstra Mobile Comms;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50501F Block 2: Lock 1: CLOSED -> Lock Data: 50501F Reading phone...Type: RM-198, Ver: 04.26 Reading imei... Imei: 358061015125685 Reading HW ID...1402 Found general data... Waiting for TP confirmation............................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 5050100058056920 Provider: Telstra Mobile Comms;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Done! |
| | #3 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Dec 2007
Member: 655243 Status: Offline Thanks: 0
| Please tell us how you modified your cable. A customer wants his 6085 unlocked. It is also locked to Telstra. It is version 4.26. Is there a way to unlock the 6085 v4.26 without modified cable? |
| | #4 (permalink) | |
| Quote:
The way I modified as the what has been discussed in this forum. Please search as I can't remember which thread and I don't want to tell you the wrong way to modify the cable in case I miss out something. tks SS | |
| | #5 (permalink) | |
| Super Moderator ![]() Join Date: Jan 2004 Location: INDIA,Gujarat,Surat Age: 28
Member: 49752 Status: Offline Sonork: 100.112446 Thanks: 104
| Quote:
see data cable on pcb and clk cable at pcb you found there are fuse soldered. just remove them and make join line nothing on center of that's wire. that's enough. now use it.must work | |
| | #6 (permalink) |
| thank you stanner.. but i dont understand what you are saying. please explain again. i opened my tp box, all the wires are soldered to the board. i dont see any fuse in there. my tp cable works for other fones. |
| | #7 (permalink) | |
| Quote:
snap both side. | |
| | #8 (permalink) |
| why are you referring to TP cable? I thought we had to modify the 6085 cable .. the one with the black box that fits into the back of the phone like battery.... with 7-pin ... to flash it, i wont use TP, right? |
| | #9 (permalink) | |
| Quote:
strange man you are. anyway attached small home made image to get idea for people who can understand. | |
| | #11 (permalink) |
| tried to edit my post, but the edit option isnt there :S so brother stanner_austin, can u point out on my photo which parts to remove and which parts to join? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 5200... Not all version available today can be unlocked | -luigi- | BB5BOX | 4 | 04-06-2008 00:36 |
| V3 boot loader 08.26 can be unlock By UBL? | denard | Ultima Box Light | 7 | 11-27-2007 17:27 |
| What Version GX17-GX29 Can Be Unlocked And What Flash Files | mbcommunication | Sharp | 1 | 09-13-2007 18:07 |
| UST Pro version 4.50b can not unlock SoftBank new version | SoftBank705SC | UST Pro II | 2 | 04-03-2007 06:31 |
| What versions of z600 can be unlocked with div8.4? | swampen | Sony Ericsson | 9 | 12-28-2003 20:30 |
