01-30-2008, 04:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2006
Member: 384641 Status: Offline Thanks Meter: 31 | Error unlocking code 07 Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3340309996332460 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 33403F Block 2: Lock 1: CLOSED -> Lock Data: 70403F Block 3: Lock 1: CLOSED -> Lock Data: 70604F Block 4: Lock 1: CLOSED -> Lock Data: 71030F Block 5: Lock 1: CLOSED -> Lock Data: 71402F Block 6: Lock 1: CLOSED -> Lock Data: 72207F Block 7: Lock 1: CLOSED -> Lock Data: 73002F Block 8: Lock 1: CLOSED -> Lock Data: 73212F Block 9: Lock 1: CLOSED -> Lock Data: 74000F Block 10: Lock 1: CLOSED -> Lock Data: 74807F Block 11: Lock 1: CLOSED -> Lock Data: 21407F Block 12: Lock 1: CLOSED -> Lock Data: 21402F Block 13: Lock 1: CLOSED -> Lock Data: 71606F Reading phone...Type: RM-147, Ver: 03.50 Reading imei... Imei: 352732015265301 Reading HW ID...3001 Found general data... Waiting for TP confirmation.....................................S ending code... Error unlocking! Code: 07 My number Pkey is JAF version 1.98.45 Detected PKEY: 9000C33D Card life counter: 99.96% P-key nokia module version 01.00 |
01-30-2008, 09:26 | #2 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | I Think ............. Quote:
2 ND IF YOU D'ONT HAVE MAKE ASK 2 RPL BR.DYNET | |
01-30-2008, 15:39 | #4 (permalink) |
Member: 384641 Status: Offline Thanks Meter: 31 | Please chek my P-key Please chek activation of my P-key because all to unlock all phone display message UNLOCK ERROR whit all cell phone my serial P-key is 9000C33D Thank you |
01-30-2008, 15:51 | #5 (permalink) |
Member: 384641 Status: Offline Thanks Meter: 31 | Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3340309996332460 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 33403F Block 2: Lock 1: CLOSED -> Lock Data: 70403F Block 3: Lock 1: CLOSED -> Lock Data: 70604F Block 4: Lock 1: CLOSED -> Lock Data: 71030F Block 5: Lock 1: CLOSED -> Lock Data: 71402F Block 6: Lock 1: CLOSED -> Lock Data: 72207F Block 7: Lock 1: CLOSED -> Lock Data: 73002F Block 8: Lock 1: CLOSED -> Lock Data: 73212F Block 9: Lock 1: CLOSED -> Lock Data: 74000F Block 10: Lock 1: CLOSED -> Lock Data: 74807F Block 11: Lock 1: CLOSED -> Lock Data: 21407F Block 12: Lock 1: CLOSED -> Lock Data: 21402F Block 13: Lock 1: CLOSED -> Lock Data: 71606F Reading phone...Type: RM-147, Ver: 03.50 Reading imei... Imei: 352732015265301 Reading HW ID...3001 Found general data... Waiting for TP confirmation...................................Sen ding code... Error unlocking! Code: FFFFFFFF |
01-31-2008, 20:24 | #8 (permalink) |
Junior Member Join Date: Apr 2003 Location: Portugal Age: 53
Member: 27016 Status: Offline Thanks Meter: 1 | I did an end of test point, 1.98.45 is still in same with the version I went to another computer installed the version 1.98.44 and alone me of the error unlocking ,ground this ok |
02-01-2008, 15:39 | #9 (permalink) | |
Freak Poster Join Date: May 2002 Location: portugal Age: 41
Member: 12340 Status: Offline Thanks Meter: 2 | Quote:
Use external power supply also, you ll get better results. I was in the same situation that you, and now v-spec work fine | |
ned unlock code for sagem my W-8 | nokia4m | Phone Unlocking Codes & Maps | 2 | 05-03-2010 17:23 |
Need unlock CODE FOR 8900 CURVE | mbagen | BlackBerry (RIM) | 1 | 03-29-2010 12:16 |
6125 Error unlocking! Code: 07 | Tomas10 | J.A.F. Plus | 3 | 08-11-2008 21:24 |
N73 Error Unlock : Code 07 | sidcell | J.A.F. V-SPEC | 11 | 03-17-2008 06:25 |
