12-07-2007, 19:03 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 51
Member: 133320 Status: Offline Thanks Meter: 0 | n75 Detected PKEY: 9000C30D Card life counter: 91.23% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... Failed! Aborting! IMEI FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06wk15v30 14-12-06 RM-128 (c) Nokia. HW version: 4202 PCI version: RFIC version: 17141714 DSP version: chx_06wk14v38 Retu version: 15 Tahvo version: 22 Production serial number: SFG334242 Product code: 0527376 Module code: Basic production code: 0527375 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 354815010008848 IMEI spare to net: 3A 45 18 05 01 00 88 04 IMEI SV to net: 33 45 18 05 01 00 88 04 F4 LOCK STATUS: CONFIG KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-128.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0527376 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-128\RM128_10.1.282.C00 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-128\RM128_10.1.282_prd.V30 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-128\RM128_10.1.282.U30 No erase block detected! Erase will be skiped! APE Variant file: NONE Done! Changing mode... Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Reading phone...Type: RM-128, Ver: 06wk15v30 Reading imei... Imei: 354815010008848 Version Not supported! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Reading phone...Type: RM-128, Ver: 06wk15v30 Reading imei... Imei: 354815010008848 Version Not supported! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Reading phone...Type: RM-128, Ver: 06wk15v30 Reading imei... Imei: 354815010008848 Version Not supported! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Reading phone...Type: RM-128, Ver: 06wk15v30 Reading imei... Imei: 354815010008848 Version Not supported! |
+ Green light for Cingular branded N75 | apocalypso | Nokia Base Band 5 ( BB-5 ) | 0 | 11-03-2006 10:51 |
+ Nokia N75, Another addition to N family?! | apocalypso | Nokia Base Band 5 ( BB-5 ) | 1 | 09-06-2006 14:05 |
