error unlocking 08 what ever... My Solution 1 Attachment(s) well people, here is my solution to stop the ****ing error that everybody had: 1. modified your cables 2. remove fuses from clk and data. 3. remove completely clk and data (when i say completely, you remove all the wires from testpoints) 4. put clk in the place of data 5. remove cable from data testpoint. replace with finner cable, like i use on ps2 modchip, just a little bit lesser than the original length 6. reassemble cable and you re done Now is the other part to make unlock successful: instead of using cable to power the phone, i used and external supply +-4v. then connect from cable to phone bsi, connector and finally test points on unlocking. And then bye bye unlocking error |
Hi, could You show cables after modification |
Ok, no problem soon i open the shop, i will take a picture of cables ;) I wana make something clear... If unlock fail after all that modifications, don't worry is not your fault, it's just vspec that don't support chip from phone... SPECIAL THANKS TO ALL V-SPEC USERS THAT MAKE TESTS ABOUT CABLES... without you people, i ll never unlock a dam phone with v-spec ;) OFFTOPIC: And i will say something really bad for my reseller, thank you for no support you did gave me after all money i spend with you... And thank you for your ****ing message "Gsm Unlock need time and dedication"... Well **** off for no responsabilities you take about the products you sale.... 10 years that i am your *******r and you tell me this... **** off |
Many tks.... i will translate this post to portuguese and put in my forum ;) www.bus-n-tech.biz/forum/ Also all portuguese users can check my forum cause we help and give support for all boxes in market, all forum in portuguese ;) PS: IT`s true gsm field need dedication and also time, when u help yourself ur helping others.... resselers donīt have fault that suppliers sell faulty cable... also making tests and learning just helps u get smarter and smarter |
Sorry for the upper post... ehehhehe i made mistake ;) I tested your solution... and it works 100% seems like it depends from computer to computer also... in my store its works in my IBM without modification like a charm... in other computers didnīt work without modification, i had to do the same as u... funny is many *******rs were complaining from the same reason as u about the cables and i wasnīt finding the reason for the complains cause all my bb5 box are installed in my IBM :( Many tks for helping all of us in this matter :D www.bus-n-tech.biz |
help!!!! Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-126.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0537266 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 3, FBUS Code count: 2 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310170 Block 3: Lock 1: CLOSED -> Lock Data: 310200 Block 4: Lock 1: CLOSED -> Lock Data: 310210 Block 5: Lock 1: CLOSED -> Lock Data: 310220 Block 6: Lock 1: CLOSED -> Lock Data: 310230 Block 7: Lock 1: CLOSED -> Lock Data: 310240 Block 8: Lock 1: CLOSED -> Lock Data: 310250 Block 9: Lock 1: CLOSED -> Lock Data: 310260 Block 10: Lock 1: CLOSED -> Lock Data: 310270 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Block 19: Lock 1: CLOSED -> Lock Data: 310160 Block 20: Lock 1: CLOSED -> Lock Data: 310170 Block 21: Lock 1: CLOSED -> Lock Data: 310200 Block 22: Lock 1: CLOSED -> Lock Data: 310210 Block 23: Lock 1: CLOSED -> Lock Data: 310220 Block 24: Lock 1: CLOSED -> Lock Data: 310230 Block 25: Lock 1: CLOSED -> Lock Data: 310240 Block 26: Lock 1: CLOSED -> Lock Data: 310250 Block 27: Lock 1: CLOSED -> Lock Data: 310260 Block 28: Lock 1: CLOSED -> Lock Data: 310270 Block 29: Lock 1: CLOSED -> Lock Data: 310310 Block 30: Lock 1: CLOSED -> Lock Data: 310490 Block 31: Lock 1: CLOSED -> Lock Data: 310530 Block 32: Lock 1: CLOSED -> Lock Data: 310580 Block 33: Lock 1: CLOSED -> Lock Data: 310590 Block 34: Lock 1: CLOSED -> Lock Data: 310640 Block 35: Lock 1: CLOSED -> Lock Data: 310660 Block 36: Lock 1: CLOSED -> Lock Data: 310800 Reading phone...Type: RM-126, Ver: 05.60 Reading imei... Imei: 355536019359011 Reading HW ID...8009 Found general data... Waiting for TP confirmation.......................Sending code... Error unlocking! |
