Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 01-24-2008, 02:09   #1 (permalink)
Member: 12340
Lightbulb error unlocking 08 what ever... My Solution
well people, here is my solution to stop the ****ing error that everybody had:
1. modified your cables
2. remove fuses from clk and data.
3. remove completely clk and data (when i say completely, you remove all the wires from testpoints)
4. put clk in the place of data
5. remove cable from data testpoint. replace with finner cable, like i use on ps2 modchip, just a little bit lesser than the original length
6. reassemble cable and you re done
Now is the other part to make unlock successful:
instead of using cable to power the phone, i used and external supply +-4v.
then connect from cable to phone bsi, connector and finally test points on unlocking.
And then bye bye unlocking error
Old 01-24-2008, 10:03   #2 (permalink)
Member: 292240
Hi, could You show cables after modification
Old 01-24-2008, 13:55   #3 (permalink)
Member: 12340
Ok, no problem
soon i open the shop, i will take a picture of cables
I wana make something clear... If unlock fail after all that modifications, don't worry is not your fault, it's just vspec that
don't support chip from phone...
SPECIAL THANKS TO ALL V-SPEC USERS THAT MAKE TESTS ABOUT CABLES... without you people, i ll never unlock a dam phone with v-spec
OFFTOPIC:
And i will say something really bad for my reseller, thank you for no support you did gave me after all money i spend with you... And thank you for your ****ing message "Gsm Unlock need time and dedication"... Well **** off for no responsabilities you take about the products you sale.... 10 years that i am your *******r and you tell me this... **** off
Old 01-24-2008, 20:06   #4 (permalink)
strangerboy's Avatar
Member: 3783
Many tks.... i will translate this post to portuguese and put in my forum
www.bus-n-tech.biz/forum/
Also all portuguese users can check my forum cause we help and give support for all boxes in market, all forum in portuguese
PS: IT`s true gsm field need dedication and also time, when u help yourself ur helping others.... resselers donīt have fault that suppliers sell faulty cable... also making tests and learning just helps u get smarter and smarter
Old 01-24-2008, 20:06   #5 (permalink)
Member: 3783
some usefull post for u
http:///vbb/showthread.php?t=493913
Old 01-25-2008, 06:31   #6 (permalink)
Member: 3783
Sorry for the upper post... ehehhehe i made mistake
I tested your solution... and it works 100% seems like it depends from computer to computer also... in my store its works in my IBM without modification like a charm... in other computers didnīt work without modification, i had to do the same as u... funny is many *******rs were complaining from the same reason as u about the cables and i wasnīt finding the reason for the complains cause all my bb5 box are installed in my IBM
Many tks for helping all of us in this matter
www.bus-n-tech.biz
Old 02-20-2008, 03:13   #7 (permalink)
Member: 517524
help!!!!
Searching for saved ini...
Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-126.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0537266
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Done!
Backup simlock data first...
Reading IMEI...
Backup already done, skiping...
Detecting phone...
Reading simlock...
LOCK STATUS:
CONFIG KEY: 3102000000000000
Provider: T-Mobile;U.S.A.
Key Code count: 3, FBUS Code count: 2
Block 1:
Lock 1: CLOSED -> Lock Data: 310160
Block 2:
Lock 1: CLOSED -> Lock Data: 310170
Block 3:
Lock 1: CLOSED -> Lock Data: 310200
Block 4:
Lock 1: CLOSED -> Lock Data: 310210
Block 5:
Lock 1: CLOSED -> Lock Data: 310220
Block 6:
Lock 1: CLOSED -> Lock Data: 310230
Block 7:
Lock 1: CLOSED -> Lock Data: 310240
Block 8:
Lock 1: CLOSED -> Lock Data: 310250
Block 9:
Lock 1: CLOSED -> Lock Data: 310260
Block 10:
Lock 1: CLOSED -> Lock Data: 310270
Block 11:
Lock 1: CLOSED -> Lock Data: 310310
Block 12:
Lock 1: CLOSED -> Lock Data: 310490
Block 13:
Lock 1: CLOSED -> Lock Data: 310530
Block 14:
Lock 1: CLOSED -> Lock Data: 310580
Block 15:
Lock 1: CLOSED -> Lock Data: 310590
Block 16:
Lock 1: CLOSED -> Lock Data: 310640
Block 17:
Lock 1: CLOSED -> Lock Data: 310660
Block 18:
Lock 1: CLOSED -> Lock Data: 310800
Block 19:
Block 20:
Block 21:
Block 22:
Block 23:
Block 24:
Block 25:
Block 26:
Block 27:
Block 28:
Block 29:
Block 30:
Block 31:
Block 32:
Block 33:
Block 34:
Block 35:
Block 36:
Reading phone...Type: RM-126, Ver: 05.60
Reading imei...
Imei: 355536019359011
Reading HW ID...8009
Found general data...
Waiting for TP confirmation.......................Sending code...
Error unlocking!
what is the solution of damage Potato BOX ???? ..::MOBILES::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 17:03
this error with SL75 what is the solution????? please!! dvdaio S-Gold Based Phones 23 05-31-2008 07:09
error unlocking 08 error unlocking 08 error unlocking 08 give right solu.!!!!!! kalpeshoza J.A.F. V-SPEC 5 01-26-2008 07:57
error unlocking but you get my 10 credit. carlluvjo Universalbox 0 08-01-2007 14:15
Page generated in 0.51653 seconds with 12 queries
