Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 02-08-2008, 11:06   #1 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Problem Unlocking N95
@V-spec Supporters
i'm trying to unlock one N95 but always getting error failed after connecting TP. here is the log.
08:02:2008 13:16 -> JAF version 1.98.45
Detected PKEY: 9000........
08:02:2008 13:16 -> Card life counter: 99.76%
08:02:2008 13:16 -> P-key nokia module version 01.00
08:02:2008 13:16 -> Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
08:02:2008 13:16 -> JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
08:02:2008 13:16 -> JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
08:02:2008 13:16 -> JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
08:02:2008 13:16 -> JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
08:02:2008 13:16 -> Changing mode...08:02:2008 13:16 -> Done!
08:02:2008 13:16 -> FILES SET FOR FLASHING:
08:02:2008 13:16 -> MCU Flash file: NONE
08:02:2008 13:16 -> PPM Flash file: NONE
08:02:2008 13:16 -> CNT Flash file: NONE
08:02:2008 13:16 -> APE Variant file: NONE
08:02:2008 13:16 -> Switching to serial...
08:02:2008 13:16 -> Powering the phone...
08:02:2008 13:17 -> Failed! Aborting!
08:02:2008 13:17 -> FILES SET FOR FLASHING:
08:02:2008 13:17 -> MCU Flash file: NONE
08:02:2008 13:17 -> PPM Flash file: NONE
08:02:2008 13:17 -> CNT Flash file: NONE
08:02:2008 13:17 -> APE Variant file: NONE
08:02:2008 13:17 -> Switching to serial...
08:02:2008 13:17 -> Powering the phone...
08:02:2008 13:18 -> FILES SET FOR FLASHING:
08:02:2008 13:18 -> MCU Flash file: NONE
08:02:2008 13:18 -> PPM Flash file: NONE
08:02:2008 13:18 -> CNT Flash file: NONE
08:02:2008 13:18 -> APE Variant file: NONE
08:02:2008 13:18 -> Switching to serial...
08:02:2008 13:18 -> Powering the phone...
08:02:2008 13:18 -> Reading...
08:02:2008 13:18 -> MCU SW version: V 06wk41v31
05-06-07
RM-159
(c) Nokia
08:02:2008 13:18 -> HW version: 5900
08:02:2008 13:18 -> PCI version:
08:02:2008 13:18 -> RFIC version:  17141714
08:02:2008 13:18 -> DSP version: dsprap_pb06w41v34
08:02:2008 13:18 -> Retu version: 15
08:02:2008 13:18 -> Tahvo version: 22
08:02:2008 13:18 -> Production serial number: SGI750479
08:02:2008 13:18 -> Product code: 0551192
08:02:2008 13:18 -> Module code:
08:02:2008 13:18 -> Basic production code: 0530865
08:02:2008 13:18 -> Flash code:
08:02:2008 13:18 -> Order number:
08:02:2008 13:18 -> Product specific data:
08:02:2008 13:18 -> Long production SN: 0
08:02:2008 13:18 -> ATO:
08:02:2008 13:18 -> Default SN type:
08:02:2008 13:18 -> IMEI plain: 356996013365076
08:02:2008 13:18 -> IMEI spare to net: 3A 65 99 06 31 63 05 07
08:02:2008 13:18 -> IMEI SV to net: 33 65 99 06 31 63 05 07 F6
08:02:2008 13:18 ->
LOCK STATUS:
CONFIG KEY: 2343300000000000
08:02:2008 13:18 -> Provider: Orange;United Kingdom
08:02:2008 13:18 -> Key Code count: 0, FBUS Code count: 0
08:02:2008 13:18 ->
Block 1:
08:02:2008 13:18 -> Lock 1: CLOSED -> Lock Data: 23433F 08:02:2008 13:18 ->
Block 2:
08:02:2008 13:18 -> Lock 1: CLOSED -> Lock Data: 23486F 08:02:2008 13:18 ->
Block 3:
Block 4:
08:02:2008 13:18 -> Searching for saved ini...
08:02:2008 13:18 -> Checking for file C:\Program Files\ODEON\JAF\JAF_RM-159.ini
08:02:2008 13:18 -> Saved INI not found, loading INI list...
08:02:2008 13:18 -> Setting local mode...
08:02:2008 13:18 -> Failed! Aborting!
08:02:2008 13:18 -> Done!
08:02:2008 13:21 -> Backup simlock data first...
08:02:2008 13:21 -> Setting local mode...
08:02:2008 13:21 -> Reading IMEI...
08:02:2008 13:21 -> C:\Program Files\ODEON\JAF\ProgData\RM-159_356996013365076_06wk41v31_LCK_backup.pm
08:02:2008 13:21 -> Done!
08:02:2008 13:21 -> Detecting phone...
08:02:2008 13:21 -> Reading simlock...
08:02:2008 13:21 ->
LOCK STATUS:
08:02:2008 13:21 -> Provider: Orange;United Kingdom
08:02:2008 13:21 -> Key Code count: 0, FBUS Code count: 0
08:02:2008 13:21 ->
Block 1:
08:02:2008 13:21 -> Lock 1: CLOSED -> Lock Data: 23433F 08:02:2008 13:21 ->
Block 2:
08:02:2008 13:21 -> Lock 1: CLOSED -> Lock Data: 23486F 08:02:2008 13:21 ->
Block 3:
Block 4:
08:02:2008 13:21 -> Reading phone...08:02:2008 13:21 -> failed!
08:02:2008 13:21 -> Backup already done, skiping...
08:02:2008 13:21 ->
LOCK STATUS:
08:02:2008 13:21 ->
Block 1:
Block 2:
Block 3:
Block 4:
08:02:2008 13:21 -> Reading phone...08:02:2008 13:21 -> Type: RM-159, Ver: 06wk41v31
08:02:2008 13:21 -> Reading imei...
08:02:2008 13:21 -> Imei: 356996013365076
08:02:2008 13:21 -> Reading HW ID...08:02:2008 13:21 -> 5900
08:02:2008 13:21 -> Found general data...
08:02:2008 13:21 -> Waiting for TP confirmation...08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:21 -> .08:02:2008 13:22 -> Failed!
any help will be appriciated.
Take Care
ENJOY
Old 02-08-2008, 18:10   #2 (permalink)
Member: 329458
Downgrade to ver 11.0.026...
Old 02-09-2008, 04:48   #3 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
No need downgrade..Use external power supply for voltage and modify cable.thats all
Old 02-09-2008, 07:13   #4 (permalink)
Member: 133436
Sonork: 100.1577364
Can you tell me how to modify cable???? and how to use External Power Supply and where to connect external supply , do u mean no need to connect + , - , gnd cable else i should your external power supply???
any official confirm this reply ???
Take Care
ENJOY
Old 02-09-2008, 11:28   #5 (permalink)
Member: 329458
I have downgraded mine n95, and it was unlocking without external power supply and without modification cable...
problem unlocking n95s Foneish MT-BOX 6 07-10-2008 01:37
Problem unlocking N95 teerak2uk J.A.F. Plus 8 01-03-2008 09:16
Bad Problem Unlocking N95 petermov MT-BOX 3 11-19-2007 20:06
Problem unlocking N95 tito millo MT-BOX 4 11-08-2007 23:51
Problem unlocking N95 tomaszwl MT-BOX 16 09-01-2007 12:56
Page generated in 0.30144 seconds with 11 queries
