Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007
Member: 550056 Status: Offline Thanks: 34
| succefully unlock nokia 6133b Hi, i recently unlock a nokia 6133b firmware 5.60. rm126 its works!!! try to unlock with the v-spec this machine realy make money this is the log: ![]() ![]() ![]() ![]() JAF version 1.98.43 Detected PKEY: xxxxxxxx Card life counter: 94.56% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.60 17-11-06 RM-126 (c) Nokia. HW version: 8009 PCI version: RFIC version: 17211721 DSP version: dsp_mojito_05w46v31.1 PPM version: V 05.60 17-11-06 RM-126 (c) Nokia. NTM Retu version: 32 Tahvo version: 53 Content Pack version: ml5.14 Production serial number: RIK561117 Product code: 0537266 Module code: 0203022 Basic production code: 0528663 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 3555xxxxxxxxxxxxxxxxx IMEI spare to net: 3A 55 3xxxxxxxxxxxxxxxxx IMEI SV to net: 33 55 35 06 4xxxxxxxxxxxxxxxxxxx LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310170 Block 3: Lock 1: CLOSED -> Lock Data: 310200 Block 4: Lock 1: CLOSED -> Lock Data: 310210 Block 5: Lock 1: CLOSED -> Lock Data: 310220 Block 6: Lock 1: CLOSED -> Lock Data: 310230 Block 7: Lock 1: CLOSED -> Lock Data: 310240 Block 8: Lock 1: CLOSED -> Lock Data: 310250 Block 9: Lock 1: CLOSED -> Lock Data: 310260 Block 10: Lock 1: CLOSED -> Lock Data: 310270 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Block 19: Lock 1: CLOSED -> Lock Data: 310160 Block 20: Lock 1: CLOSED -> Lock Data: 310170 Block 21: Lock 1: CLOSED -> Lock Data: 310200 Block 22: Lock 1: CLOSED -> Lock Data: 310210 Block 23: Lock 1: CLOSED -> Lock Data: 310220 Block 24: Lock 1: CLOSED -> Lock Data: 310230 Block 25: Lock 1: CLOSED -> Lock Data: 310240 Block 26: Lock 1: CLOSED -> Lock Data: 310250 Block 27: Lock 1: CLOSED -> Lock Data: 310260 Block 28: Lock 1: CLOSED -> Lock Data: 310270 Block 29: Lock 1: CLOSED -> Lock Data: 310310 Block 30: Lock 1: CLOSED -> Lock Data: 310490 Block 31: Lock 1: CLOSED -> Lock Data: 310530 Block 32: Lock 1: CLOSED -> Lock Data: 310580 Block 33: Lock 1: CLOSED -> Lock Data: 310590 Block 34: Lock 1: CLOSED -> Lock Data: 310640 Block 35: Lock 1: CLOSED -> Lock Data: 310660 Block 36: Lock 1: CLOSED -> Lock Data: 310800 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-126.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0537266 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Powering the phone... Reading Full PM... Reading Field 1 ... Reading Field 2 ... Reading Field 4 ... Reading Field 8 ... Reading Field 11 ... Reading Field 12 ... Reading Field 13 ... Reading Field 42 ... Reading Field 43 ... Reading Field 44 ... Reading Field 50 ... Reading Field 54 ... Reading Field 55 ... Reading Field 56 ... Reading Field 58 ... Reading Field 59 ... Reading Field 60 ... Reading Field 61 ... Reading Field 65 ... Reading Field 66 ... Reading Field 67 ... Reading Field 76 ... Reading Field 84 ... Reading Field 87 ... Reading Field 88 ... Reading Field 91 ... Reading Field 96 ... Reading Field 107 ... Reading Field 110 ... Reading Field 111 ... Reading Field 116 ... Reading Field 117 ... Reading Field 123 ... Reading Field 153 ... Reading Field 165 ... Reading Field 181 ... Reading Field 182 ... Reading Field 183 ... Reading Field 184 ... Reading Field 185 ... Reading Field 186 ... Reading Field 187 ... Reading Field 188 ... Reading Field 190 ... Reading Field 191 ... Reading Field 193 ... Reading Field 200 ... Reading Field 202 ... Reading Field 213 ... Reading Field 215 ... Reading Field 217 ... Reading Field 218 ... Reading Field 225 ... Reading Field 232 ... Reading Field 238 ... Reading Field 250 ... Done! Backup simlock data first... Setting local mode... Reading IMEI... C:\Archivos de programa\ODEON\JAF\ProgData\RM-126_35553xxxxxxxx_05.60_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310170 Block 3: Lock 1: CLOSED -> Lock Data: 310200 Block 4: Lock 1: CLOSED -> Lock Data: 310210 Block 5: Lock 1: CLOSED -> Lock Data: 310220 Block 6: Lock 1: CLOSED -> Lock Data: 310230 Block 7: Lock 1: CLOSED -> Lock Data: 310240 Block 8: Lock 1: CLOSED -> Lock Data: 310250 Block 9: Lock 1: CLOSED -> Lock Data: 310260 Block 10: Lock 1: CLOSED -> Lock Data: 310270 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Block 19: Lock 1: CLOSED -> Lock Data: 310160 Block 20: Lock 1: CLOSED -> Lock Data: 310170 Block 21: Lock 1: CLOSED -> Lock Data: 310200 Block 22: Lock 1: CLOSED -> Lock Data: 310210 Block 23: Lock 1: CLOSED -> Lock Data: 310220 Block 24: Lock 1: CLOSED -> Lock Data: 310230 Block 25: Lock 1: CLOSED -> Lock Data: 310240 Block 26: Lock 1: CLOSED -> Lock Data: 310250 Block 27: Lock 1: CLOSED -> Lock Data: 310260 Block 28: Lock 1: CLOSED -> Lock Data: 310270 Block 29: Lock 1: CLOSED -> Lock Data: 310310 Block 30: Lock 1: CLOSED -> Lock Data: 310490 Block 31: Lock 1: CLOSED -> Lock Data: 310530 Block 32: Lock 1: CLOSED -> Lock Data: 310580 Block 33: Lock 1: CLOSED -> Lock Data: 310590 Block 34: Lock 1: CLOSED -> Lock Data: 310640 Block 35: Lock 1: CLOSED -> Lock Data: 310660 Block 36: Lock 1: CLOSED -> Lock Data: 310800 Reading phone...Type: RM-126, Ver: 05.60 Reading imei... Imei: 3555xxxxxxxxxxxxxxxx Waiting for TP confirmation..............................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Block 5: Lock 1: OPEN Block 6: Lock 1: OPEN Block 7: Lock 1: OPEN Block 8: Lock 1: OPEN Block 9: Lock 1: OPEN Block 10: Lock 1: OPEN Block 11: Lock 1: OPEN Block 12: Lock 1: OPEN Block 13: Lock 1: OPEN Block 14: Lock 1: OPEN Block 15: Lock 1: OPEN Block 16: Lock 1: OPEN Block 17: Lock 1: OPEN Block 18: Lock 1: OPEN Block 19: Lock 1: OPEN Block 20: Lock 1: OPEN Block 21: Lock 1: OPEN Block 22: Lock 1: OPEN Block 23: Lock 1: OPEN Block 24: Lock 1: OPEN Block 25: Lock 1: OPEN Block 26: Lock 1: OPEN Block 27: Lock 1: OPEN Block 28: Lock 1: OPEN Block 29: Lock 1: OPEN Block 30: Lock 1: OPEN Block 31: Lock 1: OPEN Block 32: Lock 1: OPEN Block 33: Lock 1: OPEN Block 34: Lock 1: OPEN Block 35: Lock 1: OPEN Block 36: Lock 1: OPEN Done! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Succes unlock nokia 2330c MCU Version V 08.20 | ysmayl | Cyclonebox | 0 | 09-18-2009 12:07 |
| Succes Flash nokia N97 With Dead USB | ysmayl | Cyclonebox | 7 | 09-13-2009 23:44 |
| NOKIA 5700 RM230 succefully unlocked | timberland2 | JAF No Tp Unlocker by Cinek | 2 | 04-10-2009 12:32 |
