Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 07-28-2008, 18:29   #1 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Use V-spec As Advancebox ........ ( Testing....)
DEAR USER WHO HAVE PROBLEM OR TROUBLE IN VSPEC USEING IF ANY BUDY HAVE ANY PROBLEM ...... SO I HAVE ONE IDEA HE CAN USE ADVANCEBOX SOFTWER BY V-SPEC ...
http:///vbb/attach...1&d=1217265532
1st WHAT YOU NEED FOR THAT.....
REQUIRED...........
1 Advancebox.2.20.Inc.Crack-rev
http://rapidshare.com/files/13311481...k-rev.zip.html
2 ANY WORKING UFS (HWK NOT REQUIRED)
3 V-SPEC BOX + TEST POINT CABLE
5 MICRO SCOP ( IF ANY STRANG MODEL LIKE N80 75 73 ...ETC)
NOW TIME TO DO SOME THING NEW ............
1 MAKE FOLDER AS NAME : ADVANCEBOX AT C:\Program Files
2 EXATRACT Advancebox.2.20.Inc.Crack-rev.RAR FILE AT C:\Program Files\ADVANCEBOX
3 EXATRACT AdvanceBox v2.20 IN C:\Program Files\ADVANCEBOX\Advancebox.2.20.Inc.Crack-rev
4 RUN Crack.EXE SELECT IN TARGET FILE AdvanceBox.exe and do START
5 NOW OK ADVANCE CRACK REDY TO USE....
6 IF YOU NEED COPY SHORTCUT TO DESK TOP
NOW SAME LIKE V-SPAC ATTACH V-SPACK AT UFS AND ENJOY..........
DO THISH ON YOUR RISK MAY I NOT RESPONSIBLE FOR ANY
AXIDENT ISSU OR DON'T GIVE ME ANY FAKE OR FUNYY REPLAY
This is a discussion thread please dont spam it with thnx posts better use thnx button instead.
DONT,T DELET POST THISH IS NOT ANY KIND OF OTHER PRODUCT
ADVERTISE
The Following 2 Users Say Thank You to DYNET For This Useful Post:
Old 07-28-2008, 21:02   #2 (permalink)
siang8788's Avatar
Member: 205283
how to work?connect v-spec to ufs making tp unlock?
Old 07-28-2008, 21:16   #3 (permalink)
Member: 165586
cant make testpoint, program dont see it with nokia 6300. But after trying with your program, i unlock it with Jaf after first try.
Old 07-28-2008, 21:31   #4 (permalink)
moldovan's Avatar
Member: 23684
Sonork: 1582723
Hm...
Interesting idea, need test tomorrow.
WBR !
Old 07-28-2008, 22:13   #5 (permalink)
Member: 785885
These are some test results...
Old 07-29-2008, 04:46   #6 (permalink)
Member: 756273
do you mean that its not working or working?
Old 07-29-2008, 05:18   #7 (permalink)
Member: 785885
The way I understand from Guar forums is the the Crack software works 100%. But that UFS+VSPEC works 100% but VSPEC box with testpoint cable Crack do not see testpoint cable. Better you test and see.
Old 07-29-2008, 05:22   #8 (permalink)
anhduy2004's Avatar
Member: 556267
I want to play UFS but not play V-SPEC BOX
because I have not V-SPEC BOX and I have N-BOX and JAF+pkey and MT-BOX
I want to unlock bb5 for Advancebox
help me
Old 07-29-2008, 05:28   #9 (permalink)
Member: 785885
help me
Crack software works.
If you can make a BB5 TEST-point cable that works with UFS-box alone all your problems are solved. That is what everyone is looking for......
Old 07-29-2008, 06:04   #10 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
i hope this cable may work with ufs
Old 07-29-2008, 07:04   #11 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Originally Posted by akhil_bbsr View Post
i Hope This Cable May Work With Ufs
Dear Thish Is Not Any Type Cable Pinout Thish Is Box Pin Out
Or For Clk Or Data Testpoint You Must Need Any Bb5 Box Like V-spec
Br.dynet
Old 07-29-2008, 08:00   #12 (permalink)
bootgsm's Avatar
Member: 527800
Br.dynet
@DYNET tested when bb5 advance cracked first time you can read info but test point not detected .if you succeed please post a screenshot
Old 07-29-2008, 09:10   #13 (permalink)
anhduy2004's Avatar
Member: 556267
but I do not know where TX rX on mobile here
Old 07-29-2008, 09:32   #14 (permalink)
rgb1997's Avatar
Member: 110849
try to test
ufs+V-spec+advance TP
good luck.
Old 07-29-2008, 17:02   #15 (permalink)
Temporary banned !!
Member: 808577
Br.dynet
We tryed with a xilinx CPLD using VSPEC this is the result.
We tested the CRACK with UFS and Vspec to see what we can do. We got as far as connect TP. We connected TP and VSPEC did not see TP.
We needed to know if the software was given the problem. So we switch to AdvanceBOX and unlocking worked 100% using crack. Which means that the Crack software is working 100% all features working.
The Conclusion: is some one needs to modifying Vspec box or testpoint. To work 100% with CRACK.
Use V-spec As Advancebox ........ ( Testing....) 2 DYNET J.A.F. By Jafsupport.com 0 07-28-2008 18:36
Use V-spec As Advancebox ........ ( Testing....) DYNET Nokia Base Band 5 ( BB-5 ) 0 07-28-2008 18:32
is V600 CID49 test point the same as K608 test point !!! the new SonyEricsson (USB-Smart) 0 12-26-2005 11:03
Page generated in 0.62785 seconds with 12 queries
