Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > J.A.F. Plus
Old 05-08-2008, 12:30   #1 (permalink)
Member: 195688
Thanks Meter: 6
I can't use JAF PLUS since I bought pls help me!
I bought Jaf plus from GSM Traders (Jack pedrosa) one month before and he told me that you Pkey is from Thomas and we will activate your pkey with in 24 hours and up to now already one month passed bt I haven't unlocked a single phone with Jaf plus when ever I connect the phone I found the following error I tried with many BB5 phones bt always
Read SP data error! or Phone not supported
I contact mr Jake manytime by MSN and send the log and he said all the time your Pkey is activated and update your pkey even I update my pkey replace Jaf ini bt still problem not solved. JAF team I think this totally unfair.. pls solved my problem asap.
JAF version 1.98.47
Detected PKEY: 9000F39A
Card life counter: 99.87%
P-key nokia module version 01.01
Detected JAF INTERFACE version: 01.B0, Driver version: 20405, Library version: 30115
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05.50
14-08-07
RM-237
(c) Nokia.
HW version: 1001
PCI version:
RFIC version:  17211721
DSP version: 06w14pb_07w32
PPM version: V 05.50
14-08-07
RM-237
(c) Nokia.
C
BT MCM version: 06cc-P9.1
Retu version: 32
Tahvo version: 53
Content Pack version: Content: ctv_uk
V 05.50
14-08-07
RM-237
(c) Nokia.
Production serial number: PJG708824
Product code: 0553216
Module code: 0203291
Basic production code: 0542523
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358672012845164
IMEI spare to net: 3A 85 76 02 21 48 15 06
IMEI SV to net: 33 85 76 02 21 48 15 16 F2
LOCK STATUS:
CONFIG KEY: 8000000000000000
PROVIDER KEY: 2340000300000000
Provider: Tesco Mobile (3510i);United Kingdom
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: CLOSED -> Lock Data: 23410F
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0553216
No ini files found...
Done!
Backing up SIMLOCK data...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\358672012845164_CRT_backu p_191185.pm
Done!
Backup LCK OK!
Reading simlock data...
LOCK STATUS:
Block 1:
Reading imei...
Reading codes data...
Found codes data...
Resetting phone...
Waiting for phone...
Reading soft info...
Writing codes data...
Old 05-08-2008, 13:29   #2 (permalink)
Member: 96950
Thanks Meter: 3
are you using the option of tp unlock, in the unlock box?
j
Old 05-10-2008, 21:54   #3 (permalink)
AndreS's Avatar
Member: 36951
Sonork: 100.63212
Thanks Meter: 6,247
as i can see from your log, you are using codes option for unlock.
with this option, you are distroying SP area on your phone, or you will get version not supported.
you must select TP unlock option from jaf, and after press unlock
Old 05-13-2008, 07:22   #4 (permalink)
Member: 195688
Thanks Meter: 6
Finaly problem solved.but I'm tring to unlock 3110 and it gives always error 08. I hv unlocked many with Advancebox with out any problem.
JAF version 1.98.47
Detected PKEY: ******xx
Card life counter: 97.74%
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
Backup simlock data first...
Reading IMEI...
Backup already done, skiping...
Detecting phone...
Reading simlock...
LOCK STATUS:
Key Code count: 3, FBUS Code count: 2
Block 1:
Reading phone...Type: RM-237, Ver: 05.50
Reading imei...
Imei: 358672012822304
Reading HW ID...1001
Found general data...
Waiting for TP confirmation.............Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading imei...
Waiting for TP confirmation...............................Sending code...
Error unlocking! Code: 08
Old 05-13-2008, 21:56   #5 (permalink)
AndreS's Avatar
Member: 36951
Sonork: 100.63212
Thanks Meter: 6,247
try to put the GND near TP area
Old 11-08-2008, 23:12   #6 (permalink)
Member: 581597
i have the same with 6300
here log
Reading...
MCU SW version: V 06.01
16-01-08
RM-217
(c) Nokia.
HW version: 1000
PCI version:
DSP version: 06w14pb_07w39
PPM version: V 06.01
16-01-08
RM-217
(c) Nokia.
MEA
Retu version: 32
Tahvo version: 53
Content Pack version: Content: mea1
V 06.01
16-01-08
RM-217
(c) Nokia.
Production serial number: DJF955338
Product code: 0537630
Module code: 0203166
Basic production code: 0537040
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
IMEI plain: 353933019358600
IMEI spare to net: 3A 35 39 03 91 53 68 00
IMEI SV to net: 33 35 39 03 91 53 68 10 F5
LOCK STATUS:
CONFIG KEY: FFFFFFFFFFFFFFFF
PROVIDER KEY: FFFFFFFFFFFFFFFF
Provider: Unknown provider
Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Checking for file D:\Program Files\ODEON\JAF\JAF_RM-217.ini
MCU Flash file: D:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.mcusw
PPM Flash file: D:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.ppm_mea1
CNT Flash file: D:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.image_mea1
Languages in ppm: English,Arabic,French
Done!
Old 11-08-2008, 23:16   #7 (permalink)
Member: 581597
i trayed that TP unlock option from jaf > here log
Reading IMEI...
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading phone...Type: RM-217, Ver: 06.01
Reading imei...
Imei: 353933019358600
Reading HW ID...1000
PKEY ERROR bb5 unlock!
Old 11-08-2008, 23:23   #8 (permalink)
renegade's Avatar
Member: 426389
Thanks Meter: 2,356
Reading IMEI...
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading imei...
Of course u can't unlock it if u have SP area corrupted (FFFFFFFF)
You can repair it for free if :
1-you have good 308 backup, just restore it
2-you have BB5king activated
Or, you can buy rpl
Old 11-12-2008, 00:26   #9 (permalink)
Member: 581597
thanks man..........
i have a big problem. i bought used smart-clip pls help me ..::[email protected]::.. Smart-Clip 3 02-12-2010 12:31
please help can't access support site since i bought box 3 months ago GSMaxx Cyclonebox 0 01-02-2010 10:37
full rpl using jaf plus? japunlock J.A.F. Plus 1 11-29-2007 21:57
Page generated in 0.29206 seconds with 8 queries
