12-01-2011, 09:46 | #1 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1690745 Status: Offline Sonork: 100.1608888 Thanks Meter: 0 | [Help] MSTAR - Problem Read User Code GetInfos PASS... and STUCK When load fw backup, show user code:1122 but when flash it, user code still invalid. Whats wrong? Pin1 : pwr 4.8v pin2 : usb+ pin3 :usb- pin4 : ? pin5 : gnd This pinout, i read from SPREADTRUM tab because MSTAR tab not found any pinout. |
12-01-2011, 10:04 | #2 (permalink) |
Member: 1690745 Status: Offline Sonork: 100.1608888 Thanks Meter: 0 | platform selected!Timer: _2011_12_1_15_53_10>> MStar Platform selected! Timer: _2011_12_1_15_53_14>> Please press power key until new <usb mass storage> device coming Timer: _2011_12_1_15_53_25>> The running thread cancel by user! Timer: _2011_12_1_15_53_30>> Mstar phone attached! Timer: _2011_12_1_15_53_38>> Please press power key until new <usb mass storage> device coming Timer: _2011_12_1_15_53_39>> Mstar phone attached! DeviceNumber = 1Timer: _2011_12_1_15_53_40>> Phone connected! Disk:[H] ..ack:0x04000000Timer: _2011_12_1_15_53_40>> Get CPU ID... 03 80 40 00 Timer: _2011_12_1_15_53_40>> [GetChipID]: MSW8533x chip ID detected Timer: _2011_12_1_15_53_40>> DL->bootstrap_MSW8533x.bin Timer: _2011_12_1_15_53_40>> DL->lock_MSW8533x.bin Timer: _2011_12_1_15_53_40>> Target Version = 03 05 06 18 Timer: _2011_12_1_15_53_40>> RAMSize = 0x400000 Timer: _2011_12_1_15_53_40>> NOR Flash:NOR_ST_M30L0T7000T0 Timer: _2011_12_1_15_53_40>> FlashSize = 0X1000000 Timer: _2011_12_1_15_53_40>> GetInfos PASS... |
12-01-2011, 11:00 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Try Again.Your set will ok. Last edited by ch mobiles; 12-01-2011 at 11:30. Reason: Remove Wrong Information. |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
12-01-2011, 11:22 | #4 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | You Should Define Pinouts Manually. Define Cable As Pin1 : pwr 4.8v pin2 : usb+ pin3 :usb- pin5 : gnd. Remember Mstar Cpu Works On Mstar Tab Not on Spreadtrum. Do This & Post Result. B,R. |
The Following 3 Users Say Thank You to ch mobiles For This Useful Post: |
12-01-2011, 22:29 | #5 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 598822 Status: Offline Thanks Meter: 74 | Quote:
First Read Flash file from your Phone Load your Flash file into the Spiderman software then Spiderman software shows your USER CODE Next disconnect your (don't need re Flash) Phone and Switch ON and enter reeded USER CODE Now Your Phone O.K. for Reference http://forum.gsmhosting.com/vbb/f443...erman-1319450/ | |
The Following User Says Thank You to inseee For This Useful Post: |
12-01-2011, 22:43 | #6 (permalink) | |
GetInfos PASS... means Booting function is completed in MStar Tab. | |
12-02-2011, 15:06 | #7 (permalink) |
Member: 1690745 Status: Offline Sonork: 100.1608888 Thanks Meter: 0 | ok... @ inseee - #5 No, phone code still encrypted because the code still invalid. maybe, caused by wrong enter more than 10 times. Problem solved. Thanks. But, i have question again with other set. Using cable L14E+L12C sometimes give me an error with "ttiiiittt..!!!" sound. |
12-02-2011, 20:22 | #8 (permalink) | |
means Phone name, Model , cpu name , Problem etc..... | |
12-04-2011, 07:52 | #9 (permalink) |
Member: 1690745 Status: Offline Sonork: 100.1608888 Thanks Meter: 0 | ASIAFONE AF805 Code: Timer: _2011_12_4_13_46_22>> Please press power key until new <usb mass storage> device coming Timer: _2011_12_4_13_46_27>> Mstar phone attached! DeviceNumber = 1Timer: _2011_12_4_13_46_28>> Phone connected! Disk:[H] ..ack:0x04000000Timer: _2011_12_4_13_46_28>> Get CPU ID... 03 80 40 00 Timer: _2011_12_4_13_46_28>> [GetChipID]: MSW8533x chip ID detected Timer: _2011_12_4_13_46_28>> DL->bootstrap_MSW8533x.bin Timer: _2011_12_4_13_46_28>> DL->lock_MSW8533x.bin Timer: _2011_12_4_13_46_28>> Target Version = 03 05 06 0D Timer: _2011_12_4_13_46_28>> RAMSize = 0x800000 Timer: _2011_12_4_13_46_28>> NOR Flash:NOR_K5N2833ATM Timer: _2011_12_4_13_46_28>> FlashSize = 0X1000000 Timer: _2011_12_4_13_46_28>> GetInfos PASS... Timer: _2011_12_4_13_46_28>> Send m_CmdBuf PASS... Timer: _2011_12_4_13_46_28>> Send rand PASS... Timer: _2011_12_4_13_46_31>> Set address ok Timer: _2011_12_4_13_46_31>> Erase progress is ready! Timer: _2011_12_4_13_46_33>> Erase Len = 8EA Timer: _2011_12_4_13_46_33>> Erase whole flash start... Timer: _2011_12_4_13_46_34>> error code = 121 Is there anyway to flash MStar without erasing...? Thank you |
12-04-2011, 20:02 | #10 (permalink) | |
MStar CPU Phones compulsory erase the whole flash before writing (Flashing) Now you must need good flash file for re alive your phone so sad... Try to get good flash file from any (same phone) working phone and re flash. | |
nokia E 72 help me please (SOLVED) | lounaisse | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 06-20-2012 11:22 |
i can't read C3 | 089999945 | Cyclonebox | 8 | 12-01-2011 16:20 |
Gpgdragon team help plz | aliburhan1 | Dragon Box | 2 | 12-01-2011 06:03 |
how to enter code s5830l??? [Answered] | ..::AdnanRaj::.. | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 4 | 11-30-2011 16:51 |
Nokia 5220 contact service help me pls (SOLVED) | shahidjee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 11-29-2011 10:21 |
