Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 06-11-2009, 10:29   #46 (permalink)
Member: 422465
Thanks Meter: 23
Spiderman software problem : my S-7 china phone MTK6225 fist time my phone security lock then I format my set with spiderman software now spiderman make new problem unable to connect ,in the time I read file anther S-7 phone and full flash with spiderman software but problem same .next time I try my ok S-7 MTK6225 set format than it make unable to connect
Then I full flash anther ok set now as a same means spiderman software damage my ok 3 mobile set .
Now my 3 set found full network, when make a call than show unable to connect plz helps me
Old 06-22-2009, 21:37   #47 (permalink)
GSM-XPERTS's Avatar
Member: 1001830
Sonork: 100.1652282
Thanks Meter: 242
Great wor,k sir i am very old user of spider man ..... Nice device thanks for this great invention
like spider man ... A have already pinfinder but i dont like it slow finder and useless for me
The Following User Says Thank You to GSM-XPERTS For This Useful Post:
Old 07-11-2009, 13:39   #48 (permalink)
rahulk99k's Avatar
Member: 485686
Thanks Meter: 539
how can i find the currently firmware used in phone???plz anyone can help me???
Old 08-20-2009, 18:33   #49 (permalink)
Member: 843927
Thanks Meter: 11
thankyou very much
very great
Old 10-23-2009, 04:38   #50 (permalink)
Member: 819022
Thanks Meter: 2
Sir can give me the information about the numbers used in your thread
Old 10-23-2009, 04:43   #51 (permalink)
Member: 819022
Thanks Meter: 2
Sir can u give me the information about the numbers used in the post
1-The Connect button which use for connect box with program
If connection Is Good this button will be Disconnect
2-Select Comport which u can use
3-Select Baundrate For Comport
4-Used For Make Conaction With Phone ((Boot The Phone))
5-Used For Make Order To write selected Flash Files on Nor Flash Or Nand Flash
6-Used For Make Order To Read Flash Files Form Phone And Request for where u want to save backup flash files
7- Used For Make Format Opration and if u check to Manual Format Default this option is required to Make Manual Set For Foramt Area
8-Used For Unlock Phones ((open all network locks ))
9-Used For Find Pinout For Phone and give us Correct Tx And RX Pins
(( We Can choose From 2 Options 1St, 1 Cpu Phones - 2Nd, 2Cpu Phones ))
10- We Can Used This Option to Defind Pinouts and Save Our Correct pinouts Searching
11-This Opation allowed us To Convert Flash Files which Had Bin Extension
To Bif Extension
12-Used For Abort Any Working Opartion
13-Used TO Know Any New Updates In Support Area
14-This Bar allowed us To Change between Phone Cpu which We Have
Like MTK And SPreadtrum .......
15- here We Can Open Nor Flash which we Want To Flah it to phone
16- here we also can choose where we want to save reading flash files
17- Same as last oprations ((15-16)) But Here For Nor Flah Area
18- Used For Rebuild Iemi for Phone
19- Used For Make Full Factory Defaults
20- The Area For Read all Info About SW and Flash File Details
Old 10-23-2009, 06:05   #52 (permalink)
Member: 45873
Thanks Meter: 35
Great Mr Silver
Good Luck
regards
riaz
Old 10-25-2009, 15:45   #53 (permalink)
imran_4_u's Avatar
Member: 677987
Thanks Meter: 173
can u tell me how to do callibration with spidermnan
Old 11-04-2009, 04:18   #54 (permalink)
Member: 1114692
Can be use for N2 Phone ( MTK6235) ? my phone always on pen calibration and can't past over pen calibration setting .pls help me !
Old 12-23-2009, 08:49   #55 (permalink)
Member: 1122148
Thanks Meter: 35
sir i cnat install spiderman new update
sir i have spiderman box i want install new update of spider man like 2.61 but i cant bcs when i m installing its installing but on desktop shortcut its showing blue blank box (it sholud be the yellow colur box ) but it showing only on ebox there no any box with mtk shortcut so i m confuse is somting wrong in my computer bcs i m using MCafee antivitus ok
but i can install version 2.49 very nicly n i can work with it
so plssss how ican i use any solution sir
Old 12-24-2009, 11:20   #56 (permalink)
Member: 182513
Thanks Meter: 26
after full flash 6600 cpu same dead
Old 12-31-2009, 16:16   #57 (permalink)
Member: 179954
Sonork: There is not
I have a Chinese clone of E71 +. Soldered LCD. LCD glows white. How to record other driver LCD with SpiderMan? I click "Connect", "LCD Swich", "MTK LCD Swich universal Tool", what next?
Old 01-11-2010, 11:36   #58 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
Thanks sir for this nice information about infineon flash procedure please also tell about how to know about infineon cpu how can we know about cpu please upload the pic....
Old 01-29-2010, 15:24   #59 (permalink)
Member: 484039
Originally Posted by RaSkAl01 View Post
yes fırst pın outo good work good fınd hehe spıderman best box
hello sir pls tel me how to use universal cable
The Following User Says Thank You to kuljeetsandhu For This Useful Post:
Old 02-01-2010, 11:46   #60 (permalink)
Member: 246376
Thanks Meter: 11
good work silver gsm
How to calibrate china phone with spider man box tamungas Chinese Models & Cloned Phones 1 01-11-2012 21:03
LG KG195 unlock sucess with spider man box ..::My3gtech::.. Chinese Models & Cloned Phones 8 07-25-2011 09:15
karbonn k444 flashing with spider man box? ramcellular SpiderMan 3 08-02-2010 09:50
How to work with 2-3 boxes simultaneously! ProGsm2K7 FuriousGold 13 03-02-2010 22:41
I not know how to work with sagdd box . mileta5 SAGEM JTAG UNLOCKER 8 02-20-2009 11:49
Page generated in 0.21806 seconds with 11 queries
