Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 02-19-2009, 03:50   #1 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
How to use and how to flash chaina mobiles with spider man i am just new
Please help i just got spider man and new i dont know the procedureto flash the sets format i understand but flashing i dont know how to choose files and how to make erase and flash please help me
I will Bi very thank full to you all
Asghar Hussain
Old 02-19-2009, 05:04   #2 (permalink)
kmshawon's Avatar
Member: 502527
Sonork: 100.1580353
Thanks Meter: 113
Find Rx .tx Signles easyyy
HOW TO FIND RX .TX SIGNLES .
It is tasted and also you can test it.
1 step is, we need to find GND from phone.
2 step is, we should power on phone (operation with dead phone:
phone must be 100% dead by software)and take multimater put it to voltage.
3 multimeter (-) line put it GND and with (+) line check each connectors
, and usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v
(it will be change by processor but strongly 1.7v or 2.8v not 3v or 4v)
This way is too easy and you will save a more time.
For example!
You have got new brand China miracle phone with USB cable. It has got
12 pin. You must find (Infinity team give good Idea 1.2.3 punkts):
1) GND usually it has got 2 GND. (now we have got 10 pins)
2) We will uncheck USB + and USB- (VSS) just with checking by USB cable (now we have 8 pins)
3) By USB cable we also uncheck V bat+, ac adaptor + polarization (now we have 7 pins)
4) Now from this 7 pins you will find 1 or 3 not used pins (last operation we have 3 or 6 pins to find Rx Tx signals)
5) Now at last operation you should use good multimeter just to find Rx Tx with 1.7v-2.7v or 1.8v-2.8v
6) WHEN PHONE IS POWERD OFF TX AND GND WITH MULTIMETER MAKING BEEEEEP
(DIOD TEST OPERATION), WHEN PHONE POWERED ON IT WILL SHOW LIKE DIOD
RESISTANS 600-700 OHM BETWIN TX AND GND.
I think I have give for every body more information’s. Just try to
find. If you find 2-3 phone signals and you will be profi mobile Tx and
Rx signals finder.
Some times you will not find with this method some phones, but why we have forum?
I'm not saying it is 100% solution but I'm saying it is TESTED solution.
Old 02-19-2009, 11:56   #3 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,027
see sticky thread.
u problem will be solved
::Here How To Work With Spider-Man Box :: SiLver GSM SpiderMan 136 03-09-2012 17:58
How to flash china dead set with spider man. madni shah SpiderMan 5 02-25-2010 14:02
whats best flux to use and where to get it in the UK? The Repair Shop Hardware Equipments for GSM 0 08-06-2009 09:26
How to use and how to flash chaina mobiles samalik Infinity-Box 4 02-21-2009 10:49
can i use usb cable to flash chiniese phones via spider man ?? RazoR888 SpiderMan 1 12-01-2008 17:14
Page generated in 0.20957 seconds with 8 queries
