Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 08-03-2010, 14:49   #1 (permalink)
Vista_Mobile's Avatar
Member: 767058
Sonork: 100.1586296
Thanks Meter: 852
How to use spider box with Pinout finder Component + FAQ
In The Name off g0d
Because of so many problem that occures during the using of this powrfull box , i have decided to provide a general and comprehensive easy to use guide for pinout finder component.
I Hope it is helpfull
First of all going to see some questions and answers before we getting to work:
Q: What is this component?
Answer:: This component is a Serial to USB converter that designed for Chinese phones with Spreadtrum processor.
Q: Where is this?
Answer:: We must open the box and place the component in the proper place.
Q: Is it possible to find if we have pinout finder without trying to open the box case ?
Answer: Yes. open software then click CONNECT button ,the following pictures hepl you with that.
Q: is it neccesaary to use USB cable in order to service this series ?
Answer: No, it isn't If you have a pinout finder.
Q: How to connect the phone to box?
Answer: just like the MTK series .
Q: i saw a prob with a wiered diode , what is this BTW ?
A: the box can not identified a specific series of this phones.you have to use this in positive direction between the box and phone in order to identified this series.
The Following 42 Users Say Thank You to Vista_Mobile For This Useful Post:
Old 08-03-2010, 14:54   #2 (permalink)
Member: 767058
Sonork: 100.1586296
Thanks Meter: 852
Now We are going to describe any tabs in the software :
HARDWARE TYPE :
Spread series use different kind of MCU such as R-H-M-L nad we can choose them here.
Q:: How we can find which type of CPU do we have?
Answer:: Unfortunately, the solution is not only based on scientific testing and experience can understand, you have to test different ways that will be explained.
User define format address
We Use this option when we try to format this series with manually input format address. to use this Tick the box to enable user define Format address then put starting address in first box and end address in the second box.
Q: If we dont use this option , which address uses in format process?
Answer: predifined default address .
Q: Which one is better?
Answer: Of course automatic .
Set New IMEI After Flash Done :
as we can see , this option will change the original IMEI with the one we put in the box after the flash is compeleted.
Q : can we change the IMEI in this series without flashing ?
A : im afraid not , this is not possible for now .
with this option , the system will monitor all ports to find the right port and do not need to set it manually.
To move betwwen this two option we can use this.if it is enabled , NAND will be used otherwise NOR will be enabled.
Q : what is NAND and NOR in general ?
A : this is MCU types.
Q : How we can find which one is used ?
A : continue reading this
Nor Flash Files :
to change any options such as read and write flash file for NOR type you can use this option.
NAND Flash Files :
to change any options such as read and write flash file for NAND type you can use this option.
When we use Boot button , all information comes directly here , for example CPU type ( NAND or NOR ) IC size and etc.
The Following 28 Users Say Thank You to Vista_Mobile For This Useful Post:
Old 08-03-2010, 14:59   #3 (permalink)
Member: 767058
Sonork: 100.1586296
Thanks Meter: 852
How to use the software and work with phones :
firs of all we have to find the correct cable and coonect it to the phone and box.
run the software.
click connect.
go to Setting tab.
click Search Phone
with one of above operation you will be abble to find the pin-out.
Q : is it possible to determine which option will be suite :
A : no , in this step , we dont have any information and have to use each of options.
after using any of this options, power the phone slowly and wait until the pin-out recognized.
you can see this procedure in this picture :
now click Define Cable and not save .
after that press power button again. then you must a new hardware detection pop up.
install the driver from this path : C:\SpiderMan\Driver
now you have a specific com port for the phone .
The Following 29 Users Say Thank You to Vista_Mobile For This Useful Post:
Old 08-03-2010, 15:01   #4 (permalink)
Member: 767058
Sonork: 100.1586296
Thanks Meter: 852
read information using BOOT button
now we can find that we work with NOR or NAND and which type ( i mean M - R - H - L )
first choose one option in Hardware type and click Boot , then power the phone slowly.
now we have two different situation :
1- in the boot time this error occures :
so that means you choose wrong model type and have to change that.in this step you can not see anything in boot information.
solution :
choose next option.
2- you choose correct hardware type same as this pic :
you can see full information about the phone .
now for example we have 6600L type and NOR size.
The Following 27 Users Say Thank You to Vista_Mobile For This Useful Post:
Old 08-03-2010, 15:07   #5 (permalink)
Member: 767058
Sonork: 100.1586296
Thanks Meter: 852
how to backup :
after all that information acquired . we can create backup easily.
follow this steps :
  • select correct option from HARDWARE TYPE.
  • select NAND or NOR type.
  • Click Read button.
  • save the file in proper path and choose a name.
  • click save and power the phone slowly.
how to format :
  • make sure that USER DEFINE FORMAT ADDRESS in inactive ( unchecked )
  • click format and power the phone slowly.
how to flash and restore backup file :
  • select Format After Flash option if you want to do it after flash process.
  • select SET NEW IMEI AFTER FLASH DONE if you want to do it so ( be careful , the IMEI will not be change if you select FORMAT AFTER FLASH DONE )
  • click Flash.
  • choose your file in that window.
  • select open and power the phone slowly.
you must see this pic . No comment :
click Start tyo flash and wail till the end.
The Following 31 Users Say Thank You to Vista_Mobile For This Useful Post:
Old 08-03-2010, 15:09   #6 (permalink)
Member: 767058
Sonork: 100.1586296
Thanks Meter: 852
Br Pars-gsm
first and Best Iranian Gsm forum
best regards
V!ST@_M0B!LE
The Following 25 Users Say Thank You to Vista_Mobile For This Useful Post:
Old 08-03-2010, 15:12   #7 (permalink)
Member: 802870
Sonork: 100.1585683
Thanks Meter: 595
Greaaaaaaaaaate Post
Thanks Dear Mohamad!
The Following 11 Users Say Thank You to Farzad.m For This Useful Post:
Old 08-03-2010, 15:20   #8 (permalink)
BARAN-MOBILE's Avatar
Member: 750365
Thanks Meter: 728
tnx so much mr-ghasemi
very important thread
www.pars-gsm.com the best persian forum in the world
The Following 13 Users Say Thank You to BARAN-MOBILE For This Useful Post:
Old 08-03-2010, 16:00   #9 (permalink)
Temporary banned !!
Member: 438204
Sonork: 100.1602320
Thanks Meter: 269
very important thread For All Spiderman Users
The Following 4 Users Say Thank You to moyalaslam For This Useful Post:
Old 08-03-2010, 16:41   #10 (permalink)
Member: 815509
Sonork: jaghori
Thanks Meter: 48
Hello to all
Thanx from mohammad ghasimi it is so helpfull thered for all spider man user
PARS-GSM THE BEST IN PERSIAN FROUM
Mohammad mehdi ahmadi
Afghan-gsm-mastermind
The Following 5 Users Say Thank You to naslejavan For This Useful Post:
Old 08-05-2010, 09:57   #11 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Thanks Meter: 290
@naslejavan
Yes bro you are right ,Vista Mobile explain very well and it is a really comrehensive and easy guide that I havnt seen yet ,Thank you so much Mr Qasemi I appreciate your work.
WBR
The Following 5 Users Say Thank You to NawabN Sahoo For This Useful Post:
Old 08-06-2010, 08:40   #12 (permalink)
Cheater -Don't Deal with him-
Member: 7250
Sonork: 100.1575042
Thanks Meter: 440
keep your work friend , thx u
The Following 5 Users Say Thank You to gsm-lord For This Useful Post:
Old 08-18-2010, 14:29   #13 (permalink)
Member: 1110490
Sonork: hardknock
Thanks Meter: 4
Hi, vista mobile. A customer brings phone to unlock phone. This phone is nokia 6300 spreadtrum cpu sc 6600l. My box has pinfinder . Could you please elaborate a step by step procedure how to go about this. I tried following your guide but still cant detect phone. If i have usb cable how do i use it
secondly, on the sets board there is tx and rx how can i use them to service phone especially spreadtrum cpus. Which cable do i use.
I appreciate your detailed informations
The Following 2 Users Say Thank You to willrose For This Useful Post:
Old 08-18-2010, 14:59   #14 (permalink)
Member: 902377
Thanks Meter: 64
thanx for sharing ............................
The Following 2 Users Say Thank You to vickybaljit For This Useful Post:
Old 08-20-2010, 12:26   #15 (permalink)
Member: 1128573
Thanks Meter: 242
yes, br. it's very usefull for us, if vista mobile reply with indetails/full solution, but sorry to say that no ANSWER from vista mobile. yes we'r waiting .............
thanks
The Following 3 Users Say Thank You to mahir ashab For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.28955 seconds with 11 queries
