@ jack China And Master Ayman About The IMEI Of MTK Phones I would Like To Know How Can I Copy the IMEI OF the MTK And Spread Phones Or :confused:how Can I Get A new IMEI:confused: Becouse there Are Some Problems Will Be Solved By The IMEI Patch The Last thing IF You Can Add A Command Button To The New Update To Backup The IMEI From The New Phones B'R :)MINIHACK:) |
write ur imie and press direct imie |
Phone must be ON and showing "Insert SIM" before click on "DirectIMEI" option. Best Regards! yawarniazi |
The Question Here Is Can I write Any IMEI For Example : 123451234512345 Or it must to be the Same Of The Phone IMEI |
you can write 14 bit number. last number will auto give,14 bit number you can choose. |
o.t sir jack china why i always encounter 6300 when formatting in spiderman i encounter DA error but the address is correct... is there any address for the 6300 Q-7 china phone thanks |
also spread cect q380..after format says imei error on the display..but phone is working ok..how will i delete the text on the lcd... |
I think Your problem Will be solved And the Messege which appear will be disappear |
